Materials For Dreads?
wingerkiller
So ive read around abit and decided to give it a go on dreads as a starting project of mine, now i read something about Cold foam or even called polyuretane, cant find any on ebay realy is there any chance they go by another name or so? or someone know where i can buy this Cold Foam? :)
Yeah í've read your entire thread about it :) didnt realy get if that Black gunfoam is the same that Bombooie uses? :) if that is u saved me some hours of reasearch :p
Im gonna try to make a 3d immage of 1 dread for a pred, using booie's Meaturement, hope some foks will enjoy it :)
Made some precise calculations if someone needs Perfect meaturement from top to bot on the dread and precise lowerment in mm each mm i just finished them of, so this is what i came up with, i presume bambooie's meaturement is in inches so 1 inch =2.54cm, Lenght of dread = 61Cm, Diameter 1 ( the thick part) is 3 Cm, and the Diameter 2 (the thin part) is 0.05 MM.
then we go 3Cm - 0.05 = 2.95 Cm reduced thicknes over 61cm So a simple remake of CM to MM now would be 29.5MM Splitted on 610mm would be 0.048MM reduced thicknes on each MM of the length, :)
