Master Replicas 2005 Vader esb shell
propmainiac
Hi all
Bought a MR Esb Vader from A member here. No internals or shroud but I have a 3d printed version that I was going to use on a short heliand flash. So being a MR saber it's a little larger than a MPP. So I cut the shroud so now it fits but I'm going to have to fill the gap . Still have to smooth out the shroud. Trying to decide if the time spent is worth it. Found a seller on the 'bay auction site who says he has original MR Vader shrouds with the thumbscrew for 35$. Not a lot of money. What would you all do here?
Here's pics. Thanks for looking
propmainiac
Hi all still working on this master replicas FX Darth Vader saber. So I found a seller on eBay for the shroud comes with the d-ring and the thumbscrew. Should fit and I should have it later this week. I finally managed to get the end cap off someone that had hot glued it on I had to heat it up and then give it a good twist. To fill the gap or the hole I used a washer to glue behind it and then I trimmed down a lid for container of Dremel discs. Looks more like a heliand and cap now than an MPP but I'm happy with it.
