i'll get things started......
i am leaving my seam line all the way round the gun as i wanted a more screen accurate "stunt" look.
its gonna be rough just like the film guns, hand painted silver the works.
i went over the whole gun trying to get rid of most of the gel coat "marks"
i opened up the barrel of the gun so i could get some expanding foam in there. i wanted to give the metal rods some stability when they were inserted.
just either end has foam the middle is empty.
the guns don't come with a tip , i found that the outer cover of a zinc oxide tape roll fitted perfect over the end of the 50mm cylinder/barrel.
i added some plasticard to this and was stumpped at the hex nut shaped part until i spotted a screwdriver handle would work. i cut one up and added some filler to flatten the sides out, i added a tip from some pump action bottle. i might replace this with a smaller part as its a little big.
i then started bending my 10mm alu stock bar to the required shapes and lengths
these are away getting welded just now
in case you didn't see the junkyard post i also started work on the netted rifle sling part using pipe cleaners n super glue. it will be a static display so i don't need it to be that flexible. it can be bent into what ever shape.
thats all for now......
-z
-z
