Here are two Holocrons i got from a german Fangroup called the Mandlorian Beskar Forge.
Basically its a lighted cube.
First i adhered shader Foil in different Colors. One pale grey, one mirror grey.
After that the laser Cut aluminium Applications were glued on.
Then i had to fill the corners, cover the places where the Foil would later be visible and then had to sand it very fine.
After that i used a primer on the aluminium Parts, painted the whole thing in gold and removed the tape covers over the foil.
Thats the result of it so far.
