Making my first bio
Techuser
This week I decided I wanted a helmet but the ones on sale are kinda expensive, so started making one...
Since I never saw these clays you guys use for sale here, I'm doing a basic shape of glued newspaper and then gonna cover and detail it up in epoxi
Already ordered 1kg of epoxi, will continue this when it arrives
also I need something to mold upon on the top forehead plate, maybe a balloon
xdmray
i would suggest you use some cardboard for the dome of the bio. you will get a better shape than if you tried a balloon.
Lflank
I used a similar process for my bio:
my custom bio in progress
Techuser
Nice - I can see where you're going with the shape...keep working on it and showing the updates...
I will
Lflank indeed pretty much alike, you even thought of epoxi too haha
but you ended not using?
Today I heard about paperclay, that would be an easy mixture to make, since the epoxi will take at least one week to arrive I think I gonna start a second base shape to try with paperclay, its my first time modelling anything so it will be nice to experiment different materials anyway, if both works I gonna turn them into P1 and P2 bios
Akisha
Oh wow, Ive never seen this method used before. Good job so far! Keep us all updated an what not, your starting out with a good strong start
Lflank
I will
I ended up using three layers of paper mache (made with watered-down Elmer's Glue) and then two coats of two-part marine epoxy.
It's light but quite strong. It's probably even weatherproof, though I've not tested it.
I also ended up moving the switch for the lasersights onto the inside rear edge of the mask so it can't be seen.
Lflank
For those who might not be familiar with marine epoxy (I live in Florida so we have boat repair shops everywhere here) it's a two-part mix that comes in little cans, sort of like Bondo. It's intended for fixing minor boat damage--it's a lot like Bondo, except I think it is formulated to be more UV-resistant than Bondo.
Around here, you can find it in any hardware store, or probably even a WalMart.
Gigi
Nice work Techuser! I started paper maché-ing my helmet last week and used a balloon and a half mask on the lower part.
Lflandk - I like your post about I thought about marine epoxy, I've using magic sculpt or plumber epoxy but it's nice to know there's different kinds of it out there as options.
Techuser
Gigi have you posted your paper mache one?
My epoxi arrived and its nothing close to what I expected, looks like the spawn of satan mixed with the bastard son of plaster and chewing gum. It looks too moisty and sticks everywhere, you cant model a ball with it on your hand, its hard even to mix it, my hand started hurting in half of the lower part
I dont know if I gonna stick to it or do the rest in paperclay, or start a new one only in paperclay
Gigi
No, I haven't posted anything...because I'm intimidated by all the awesome stuff! After building my base I decided I wanted to do more of a Chopper style so I've been chopping up what I started and just started adding the epoxy putty (magic sculpt). I'm going with Chopper is because I'm a pirate and I like skulls :)
Half mask and balloon paper maché bases, both had to be trimmed
Masked them and put them together
Paper Maché-ed, then later decided to cut it up and change the style
Epoxy resin, same stuff as plumber's expoxy, 2 hour working time, can use water to soften dries in 24 hours, have to mix two parts equally.
In progress
Gigi
Oh yeah, my balloon blew into the mud during a storm while drying so you see some of that on the first pic.
Techuser
lol
Gigi I think yours will be better if you strech the eye holes more horizontally
I've put some newspaper on water today, tomorrow its going to the blender and then I'll try mixing the paper mass with the poxi to see if it gets more clay-like, cant work with this thing the way it is
I tried to see how hard it was to sand it in shape and it ended looking like a bio corroded by alien blood :)
Lifeburn
Looking good dude! I have never before seen epoxy like that, all the stuff I've ever used was clear. The stuff you're using looks more like fiberglass. Keep it up and I'm sure it will turn out good.
Gigi
Thanks for the feed back, I need to pick up a utility knife mine went missing so I've been cutting with blades and it's pretty hard to cut without a holder.
Techuser
Todays update
I mixed newspaper polp with the epoxi and it still sticks to everything and rips my gloves, but now at least I can model it, its paperpoxiclay :mad:
damn thing is weighting a lot
