Making a Comic book version of the Green Lantern Power Battery (Pic Heavy)
Re: Making a Comic book version of the Green Lantern Power Battery
I use a 1/4" X 36" aluminum rod for the handle. I just bend it by hand until it looks right.
Ok great thanks! Run Runner. In other news I will be painting the first Lantern Red for my younger brother. The second lantern will be green. I couldn't locate any reed switches so I wont be using a magnetized ring to turn it on and off :unsure. I'm sure my brother will like it just the same It is his X-mas gift.
I have gotten plenty of work done on both of the lanterns! Yay!!! I will be posting a slew of new pics very soon. Hopefully I wont manage to post them side ways again... I wouldn't hold my breath though.
Okay the first pic is of some misc. parts that I'm using for my battery, in various stages of completion.
The second pic is a picture of both the batteries for a side by side comparison both just got first layer of bondo.c
The third pic is a closer shot of just my green battery. ( I have alot of work to do on the bondo)
The fourth pic is another side by side shot.
Now here comes the fun pics.:lol
The fifth pic is kind of a teaser pic showing me that lighting needs tweaked on this battery. ( sadly it kinda looked pink in person so I went and doubled up on the red gel)
The sixth pic is a teaser of my lantern. ( oooh its green!)
The seventh and final pic for this posting is the corrected lighting for my brothers lantern. ( It came out the right red for this time)
Now I just need to go and do all the sanding, bondo'ing, wire up the lights permantely, cap off the tops, add the right symbol to the right lantern, make a battery compartment, add the handles, and paint.... So yeah still a ways to go before I'm done.
It seems that I up-loaded the pics on their sides again :confused So my bad...
I've been lurking here and just started to try to build my own lantern. Unforunately as I tried to drill the holes for the handle in the side of the globe I just shattered my globe. So, how did you guys drill out the sided of the glonbe?
Hey i didn't drill out the globe it self but if i were to try I'd mask off the area and start drilling but not using any excessive force ie letting the weight of the drill do its thing.
So yeah after my cross country move I'm gonna have to start over with this because the one that i made got smashed :facepalm guess next time ill pack it better next time...
Thatoneguy, I see that I am like two years late posting this, but I have literally just found this amazing forum! I would like to complete my own Green Lantern prop replica power battery. It looks like you have been very successful in your efforts. Are you willing to post a guide to how you did your power battery? Especially the lighting aspects. I am looking over all of the pictures, but I would appreciate any written info/directions you could (or would) be willing to provide. Thank you so much!
I am currently building one, but I am trying two different globes for the battery, the suggested 8" acrylic globe from home depot, and a 200mm Christmas ball from Walmart. I have found it easier to make the side holes for the handles with a soldering gun with a fine point. To find the center point on both spheres, I put a rubber band around the center of the globe, in the opposite direction of the existing seam (it is there, it's part of the manufacturing process). I eyeballed the globe, adjusting the rubber band until it was level across the center of the globe. Once centered, I marked a point above and below the rubber band at the seam. I then centered short section from the 1" pvc pipe over the marks, and traced a circle on the globe. I put the globe inside the bowl that was going to be used for the light funnel, and, keeping my hand holding the soldering iron steady, rotated the ball in the bowl. This took two passes, but the cut was smooth and there was no pressure to shatter the globe. I then turned the globe over and repeated the cut on the other side.
I also find the rubberband method useful for making the groove around the lantern. You just stretch the rubber band over the globe baseball style, then mark off your lines. I also used the soldering iron to make this grove, using the bowl technique to keep the lines smooth.
On the Christmas ornament battery, I am going to cut a section from a previously shattered acrylic globe to make the covering for the led's, as the ornament is solid colored plastic. Incidentally, I found a fairly bright 19 LED light at Big Lots for $5.00 that can be hacked to fit in the power battery pretty easily. The only downside is it uses a battery pack, but I am rewiring it to use a 6 volt transformer.
I am still looking for a reed switch that would work with a six volt DC transformer. If any of you have any leads, please pass them along!
