Mad Max 2 "Road Warrior" T-Top Monaro
kruleworld
This is my resin HQ monaro that i built as one of the chase cars in Mad Max 2. It's one of the crazy bad guys that joins the chase of the tanker, which is a 71 Holden Monaro HQ. Finished 2014-09-26
The front is completely from scratch, made from foil and body filler. the grille is made from styrene rod.
** build **
I started by cutting off the monaro's front.
I also cut out the roof. it looks darn thick resin.
A trick with thick resin to make it look thin is to bevel the edges
hood now fits
The front will be made from scratch. i'm starting with some foil and putty
1st and second putty layers
one of many test fit
3rd layer
shaped
more putty. note i've added masking tape to protect the front fenders/hood area.
getting there. a little bit of penciling helps keep me on track
finishing nose peak
hood scoop
i've been building the grille. it's slow, hard, detailed work
