George L.
Gang,
I've looked around at all the old postings on this subject and decided to open a new thread on the subject to gather more information from fellow Luxeon saber builders. Hopefully this new thread can gather old information and provide data/idea's for all of us using Luxeon's and building the ultimate Luxeon LED blade!
Myself : well right now all I have is a 1" cut-down thick walled 36" blade that came with the Graflex Shop Luxeon Graflex Kit. I'm using their 1" aluminum blade holder with Luxeon heat sink. I cut the blade to 36" as Erv from Plecter labs recommended it as "the optimum length". Right now the blade is a standard setup, bright at the hilt and at the tip with the mirror and dim in the middle. The Luxeon is a type III Cyan.
As mentioned, I've read through a lot of previous post. Some are using Corbin type blades, Ultra Saber's "silver look" (fiber optic?), home made with "poly" added to brighten up the center of the blade, different types of "mirrors" at the end of the tube, Erv's magic film, etc.
Also have seen different Luxeon collimator lenses 6 or 10 degrees?
Just looking for new input and idea's that the rest of you Luxeon saber builders have had good luck with. Feel any replys/input will help all of us trying to do the same type of blade setup.
A couple of summary/design points I have found:
o Seems 36" is the optimum length?
o 1" diameter tube gathers the LED light better than a 3/4" one.
o Appears thin walled tubes are brighter than the thick dueling types.
o Special films/tube liners are available, not sure of the "best" type. Corbin, Erv's "magic film", Ultra Sabers, etc.
o Some builders added, along with the main blade liner/film a "poly" or other material to help even out the blade brightness along it's length.
o Some have painted the outside of the blade.
o Some have bead blasted the outside of the blade.
o Some have bead blasted the inside the blade.
o Different types of mirror materials have been used for the blade tip.
Personally, I'm just looking to get the brightest and evenly lit blade setup and not into heavy dueling. So let's comment/reply away! I figure we can all learn from the thread (again).
Thanks in advance!
Cheers...
BTW: Happy Holidays and Merry Christmas!
Thanks in advance!
Cheers...
