Long Fall Boots (Portal 2) - Alive and starting over on pg2!
Discussion in 'Replica Costumes' started by Dagnie, May 8, 2012.
  1. Dagnie
    Dagnie Well-Known Member
    567
    Deleted
  2. Dagnie
    567
    Re: Long Fall Boots (Portal 2)
    Deleted
  3. Dagnie
    567
    Re: Long Fall Boots (Portal 2) - [One shot, so we better do it right.]
    deleted
  4. Dagnie
    567
    deleted
  5. GeektressGalore
    GeektressGalore Well-Known Member
    857
    Re: Long Fall Boots (Portal 2) - [WIP w/ images]
    First of all, this build is already fantastic. I'm keeping my eye on it for ideas on how to do my long fall boots.
    Second of all, while searching for springs for my project, I found a hanging flower pot hanger that worked really well. They're steel, so they should be able to support my 135lb figure. Your 115lbs should be no problem.
    Search places like Lowe's, Menard's, Home Depot, etc for things like that. I'd post pictures of what I have, if I could find them in the garage. XD
  6. Sedulous Studios
    Sedulous Studios Active Member
    342
    I'll be watching what you do closely! I am also in the process of building a pair of long fall boots, though I'm starting from scratch rather than using a boot (my way is probably the dumb way, but we'll see). I'm using a piece of steel bent to shape for the springs, though a carbon fiber spring would really be ideal, just more expensive and beyond my abilities right now. I tested aluminum too but the bar stock I found was not nearly strong enough to work in scale.
    How are you planning to get into/out of the boot once it's tight to your leg? Zipper? Or...? That's been a very tricky part for me, as the boot needs to be fairly substantial/not stretchy for the heel spring to offer support, yet there's no way to open it up to get in and out.
  7. nick daring
    nick daring Sr Member RPF PREMIUM MEMBER
    2,455
    Can't wait to your approach on these funky boots.
    I've seen them done in foam before but I don't think I e super accurate hard shell versions before.
    Nick
  8. Dagnie
    567
    deleted
  9. Popeanator
    Popeanator Active Member
    341
    Cool, sweet job so far. Cutting up shoes would be fun. Hope it turns out awesome!
  10. Dagnie
    567
    deleted
  11. Dagnie
    567
    deleted
  12. Dagnie
    567
    deleted
  13. Felgacarb
    Felgacarb Well-Known Member
    936
    These are looking great. I'm eagerly watching to see how they come out.
  14. Dagnie
    567
    deleted
  15. PrimoOptimoso
    PrimoOptimoso Well-Known Member
    866
    In case you haven't thought of it, I hope you're planning to solidly rig the spring bar to your leg somehow - i.e. run it into its attachment point on the boot and then through, perhaps bend it downward and continue it all the way down the back of your calf, strapped on or some such. The reason I say that is, as you step down/forward, your momentum of a bit more than your meager 115 lbs will push the bar upward with all the force concentrated on where it's attached to the shell.
    Basically, engineer the spring bar to work with your leg alone, then develop a way for the boot to go on over/around it, for safety's sake.
    It looks like there's a plate with bolts in the game model - I just don't know how strong that method of attachment will be in real life.
  16. NelBearPig
    NelBearPig Member
    181
    I never would have thought to go about it that way. Way cool.
  17. Dagnie
    567
    deleted
  18. Dagnie
    567
    deleted
  19. Dagnie
    567
    Perhaps going that route was a bad idea...
    Peeled it all off, trying another way.
    Will update on how it goes.
  20. Dagnie
    567
    We tried a new mix, new method, and it worked way better, luckily. Flexible, yet hard~
  21. Protocol
    Protocol Member
    191
    Is it just me, or does he look just like the Tenth Doctor (David Tennant)?
    Anyway, this is looking sweet!
  22. Dagnie
    567
    Trust me, you are not the first person to say that. >u>
  23. Dagnie
    567
    Oh, man, that gives me an idea for a new title that bossman will hate me for.
    He probably won't notice, anyways.
    Iiiii'll just change it for a bittle bit. *u*
  24. PrimoOptimoso
    866
    I was going to say the same thing but forgot to mention it in my post =0)
  25. Dagnie
    567
    deleted
  26. Dagnie
    567
    Gonna have to put a stopper on the progress for just a few weeks. ;u;
    We're gonna make N7 armor - a female set and male set - since I need it for a final at school pffft.
  27. Dagnie
    567
    Re: Making Long Fall Boots (Portal 2) with the Tenth Doctor. [Image heavy]
    We're gonna be getting back to this pretty soon, but bossman claims he's been working on them every now and then. Do I believe him?..... ehh... Oh well.
  28. hmynmesnthn
    hmynmesnthn New Member
    2
    Just found this thread! Would love to see some progress!! *poke poke*
  29. UsernameHere
    UsernameHere New Member
    2
    I'm planning on (eventually) making a pair of Long Fall Boots myself. I'm glad I found this thread because it's given me a lot of ideas on how to go about making them! I'm excited to see some more progress!
  30. Nobby
    Nobby Sr Member RPF PREMIUM MEMBER
    2,261
    Bit of a bump from the dead, I know, but did these ever get finished?
  31. Dagnie
    567
    I WOKE UP IN THE MIDDLE OF THE NIGHT AND REALIZED WE HAVE BEEN GOING ABOUT THESE ALL WRONG AHHHHH.
    PROGRESS, THOUGH IT HAS BEEN A YEAR, IS ABOUT TO RETURN.
    Sadly my boots and everything are in the Tri cities and I personally have moved to Seattle for college.
    So looks like I will be solo on this! No longer just the helper :O
  32. Dagnie
    567
    Buarhargh, making mah buddeh bring the boots up so I can strip them of what is already on them and start from scratch.
  33. Ciano930
    Ciano930 Well-Known Member
    867
    Hahahaha wow someone really wants to start again =P I don't blame you I guess, I've been stopped from workin on my suit for the past month and I think I'm going crazy!! Need my suit and whiskey back
  34. Dagnie
    567
    I like how you included whiskey in there.
  35. Dagnie
    567
    xxxdeleted
Share This Page
