Logan's Run wall crystal
Discussion in 'Replica Props' started by epoxinator, Mar 18, 2016.
  1. epoxinator
    epoxinator Active Member
    361
    My interpretation of the larger lifeclock/power crystals from Logan's Run. First I made it in 3D Screen Shot 2016-01-31 at 7.15.54 PM.png
    It's been evolving. I started with this reference photo. Took it into Adobe Illustrator, where I discovered I could recreate an 8th and then mirror/copy that to get the full crystal. LR Crystal 1a.jpg
    DS Operative likes this.
  2. epoxinator
    361
    Earlier version I did last year and had printed. It's not deep enough and I decided to rework it and make it even, and have all the elements touch the outer circumference, so I get a cleaner mesh with no hidden holes.
  3. epoxinator
    361
    Took the finished model and exported to an STL, then imported that into Pepakura which unfolded it into these (which I then cleaned up in Illustrator for print)
    LR wall crystal Pep 3.jpg LR wall crystal Pep 1.jpg LR wall crystal Pep 2.jpg
  4. epoxinator
    361
    Cut out, glued together, and partly painted. And I discover, I've made the 3D model LR paper crystal 3.jpg LR paper crystal 2.jpg LR paper crystal 1.jpg too flat.
    Daniel Nelms likes this.
  5. epoxinator
    361
    Scaled up the model so the crystals stuck up nearly twice as high: looks more like the film. While I was at it I scaled it up to 12". Re-exported to Pepakura, then took that into Illustrator, printed out on cardstock. Building it out of paper turns out to have saved quite a bit of money before having it 3D printed: I still had some tweaking to do on the model.
    Xolin, 19narvik40 and Funky like this.
  6. Funky
    Funky Master Member RPF PREMIUM MEMBER
    3,840
    Xolin likes this.
  7. NormanF
    NormanF Master Member RPF PREMIUM MEMBER
    2,516
    cavx likes this.
  8. epoxinator
    361
    I glued the whole thing to cardboard after cutting two pieces of cardboard into a circular base. I think it would have been better to have started off with the cardboard base: there is a certain amount of warping due to the use of white glue and card stock. Be that as it may, the paper top and cardboard are a single piece. I also started to paint it with some odds and ends of Testors paint that I've had in a box for a number of years. I started off with red, but when I emptied out the red bottle I didn't have another so finished it off with green. This is only a sealer coat to make the cardboard watertight. But it does make the crystal look pretty crappy.
    Sean likes this.
  9. epoxinator
    361
    And now for a good coat of red paint. Also, at the hardware store I happened upon a light diffuser acrylic sheet, with "micro-square" texturing that I'm hoping will be a good fit for making a translucent version with lighting. Time to revise the file for laser cutting.
    Sean likes this.
  10. Sean
    Sean Sr Member RPF PREMIUM MEMBER
    2,286
  11. epoxinator
    361
    I took one but didn't post it. Also shot one in which my phone camera couldn't handle all the red. Here goes:
    Apollo, Wes R and Sean like this.
  12. Sean
    2,286
  13. epoxinator
    361
    I finished both the 6 and the 12 in paper versions as much as I plan to. They show me the concept is workable. Next step: making the finished lamp in plastic. I was at a hardware store and happened upon a "microprism" fluorescent light diffuser. Prism diffuser plastic is what the originals were made of but that material is just too thick and the prism texture too big for this size. This diffusion material is acrylic, which is a perfect candidate for laser cutting. I accidentally broke a piece out of the diffusion sheet, so I did a test cut of a facet.
    12 and 6 inch versions.jpg 12 and 6 final.jpg crystal plastic.jpg 12 plastic step 1.jpg
    Apollo likes this.
  14. epoxinator
    361
    I took my Pepakura file and opened it in Illustrator and prepped it for laser cutting. Below are the results. Now I'm in the process of gluing them together. Once each module/crystal element is securely glued together, I will sand and grind down all the connecting edges so I can glue them all into a single piece.
    Lifeclock temp construct.jpg all but 1 crystal segment.jpg 2 crystals taped.jpg taping cut pieces.jpg [​IMG]
  15. epoxinator
    361
    I found an LED light strip with a power supply and a cord long enough to hang my life clock on the wall when it's done. I went to a plastic place today and bought some gel glue for acrylic, and a 12" acrylic disk thick enough to be a good sturdy base upon which to mount all the crystal elements. I scribed all the positions of each separate element on the top of the disk. Then I glued each flat piece into it's correct position. These will be the placement guides for each of the assembled crystal elements. I'm having to sand each down, to take into account two things:
    1. Each element has depth, and laser cutting can't do beveling, so each piece is glued inner edge to inner edge. I have to sand each piece down enough to remove enough material so each piece fits in it's proper slot. The next version, I will attempt to sand to the correct beveling before I glue them together.
    2. As I assembled them I was introducing a slight amount of variation in shape. In retrospect, next time I will create paper templates upon which to glue the pieces, so I can get more uniformity of shape.
    I only wish the company who makes the acrylic diffuser offered them in a red material. I will be trying gels between the lights and the front, and I will try red LEDs for a future version, but it would look really cool if the plastic itself were transparent red.
    Another thing that might be interesting is to get a dimmer to fade the red lights off and on, and maybe even a sound chip with the call to carrousel "bong" sound playing in time with the on/off cycle.
  16. 19narvik40
    19narvik40 Well-Known Member
    566
    Epoxinator,
    This project is looking all kinds of spanky sir !!!!!!!!!:thumbsup
  17. epoxinator
    361
    Finished gluing the face elements together. Now I need to get the side elements. I had only planned it to be about 1.5 inches deep, but my lighting experiments make me wonder if I should try a base around 4 inches deep. It looks way better when the lights aren't right up against the prism diffuser.
    complete and rear lit.jpg glue up complete.jpg glue up in progress.jpg sanding to fit.jpg
    Sean likes this.
  18. epoxinator
    361
    Finally got the time and money together to get more done on the wall crystal. I knew I wanted to fasten theflat acrylic piece onto a section of acrylic tube. I got two 4"-deep tubes (12" diameter) but that was too deep. This weekend I finally bit the bullet and cut each into two 2" deep tubes, so now I have 4. I glued the completed top element onto the top of a tube, and once that was dry I wrapped around the side element and glued it into place. This time I used an acrylic gel glue, which I regret. It's thicker than the first glue I used and much blobbier, so there are a couple of places where it dripped down the side. It seems to damage the acrylic if there is stress put on it (such as wrapping it around an acrylic cylinder) and underneath the glue blobs there are tiny cracks in the light diffuser. The first of the attached photos shows a photoshopped black color under the light diffuser on the side, which I plan to do once I get the light elements put together. I will cut circles out of particle board and drill holes through which I will push the LEDs from the christmas light set I got for the purpose. I've tried it out, as you can see in the picture with a cardboard mockup through which I've got the lights pushed up. On an interesting side note, when I try to shoot the crystal with the LED lights on, there can sometimes be dark bands through the image. Interestingly enough, the reflected light off the cardboard doesn't seem to be affected by this phenomenon.
    Carrousel light 1.jpg carrousel light 2.jpg Carrousel light 3.jpg Carrousel light 4.jpg
    Sean likes this.
  19. epoxinator
    361
    Gave away the paper power crystals. In a mistake I gave away two crystals to three different people, so I printed and cut out a third paper version to make things right. Instead of folding and using paper taps to connect them I cut out each facet separately and fastened them all together with a folded strip of paper. It came together way more tightly than the first two, and I discovered that I had made an error in alignment that explained why I had to do SO much sanding on the acrylic version before all the pieces would fit together.
    paper crystal v3 01.jpg paper crystal v3 02.jpg paper crystal v3 03.jpg paper crystal v3 06.jpg paper crystal v3 07.jpg paper crystal v3 08.jpg paper crystal v3 09.jpg
    Sean likes this.
  20. Sean
    2,286
Share This Page
