Legend of Zelda: Master Sword - Kit build
BobaFettSlave_1
I got this LoZ Master Sword kit from KevlarGorilla (aka Heroic Replicas) back on his initial run many many moons ago, and never got around to finishing it. Decided to take a break from Fett stuff and finally pulled it out of storage
Its one of his standard Resin hilt kits with the Stainless Steel CNC’d blade
Over the last few days Ive slowly worked away at hand polishing the blade. I started with 120 grit wet/dry Sandpaper and worked my way slowly up to 600 grit to bring the surface to a beautiful shine. Each side of the blade has about 6-8hrs of polishing work on it so far because there was a LOT of raw stock surface grain/scale in the non CNC’d surface that needed to be worked out without losing the beautiful lines of the edges
Blade Surface Before Polishing
Blade Surface After Polishing
Also threw the hilt in a vice and milled the top and bottoms square
Test Fit
More to come!
BobaFettSlave_1
More Progress
Started playing around with the handle.
The core of the handle is two sections of wood that are glued together, but I also decided to turn some aluminum retaining rings to sure the area up even further
The rings also have an additional recess within them to help hide the ends of the leather wrap once thats added later
PoopaPapaPalps
Boy, this is gonna turn out great. I wish I had gotten on that run when it was being offered but there was no way I could swing the cash (wanted the bronze option). Gonna be lookin' on this thread with great envy!
