Laser alignment help
Nismo300ZX
1) How do you fit the lasers into the diode that come with the bio? The ports are too small for the laser tips...
2) Supposing you got those tips into the ports, how in the DEVIL do you align them? I'm assuming clay or something similar?
Thanks.
hez1
What diameter are your lasers? I've used a couple of different ones. If you have the small 6mm ones, I just used a dremel to open up enough space for each laser to fit in. I then used JB weld to fit each laser in place. Do it one at a time, and HOLD IT as the JD weld is drying. If you're not confident and want a test run, use hot glue, but that can shift and knock the alignment out.
