John Wick - Rules Of Engagement Aluminium Cards & Display Box *Interest
MonkeyInk
Firstly I have to pay respects to the likes of jcporcel and others like who created a thread with a lot of reference material that was very helpful to create, and helped me source further to create the final design files.
I wanted to create my own John Wick Rules Of Engagement Cards made from aluminium to get as close to the final onscreen used props. After doing so it bugged me on how I would then further display the cards themselves which led me to designing a finished detailed box. I then was approached by a few friends if I could make one for them also so thought I would see if there would be any interest here.
The details are as follows;
When John Wick meets Marquis de Gramont overlooked by The Harbinger representing the high table, aluminium cards are presented to decide The Rules Of Engagement!
FULL DESCRIPTION OF EACH COMPONENT
- 24 Seperate Rules Of Engagement Card is made from 3mm aluminium, plasma cut individually, hand sanded, and the highest quality print directly onto the aluminium using UV ink.
*Each aluminium card is made to film/movie size; 4.75 x 2.75 in - 3mm depth
- Each card comes with a custom cut plastic pocket sleeve protector
- Display Box. Made from natural premium wood harder than oak or acaica wood, with gold premium hinges and latch. Designed and UV printed high table design on lid.
Full dimensions. 27 cm width x 20 cm depth x 13 cm height
- Wooden insert inside lid. Printed and cut to size to sit inside display box, printed on 3mm Plywood.
19 cm width x 13 cm height
- High Table Brass Plaque On Box. Made from solid brass, engraved and inked, drilled to the front of the box.
Dimensions. 4 in width x 3in height - 1.5 mm depth
- Inside Acrylic Card Holder. Laser cut in size and card inlets raised up on multiple 5mm sheets of acrylic and finished with UV print of high table and John Wick design. Would also work as a stand alone piece if you wanted to display without the box. Aluminium cards slide straight into the display.
All 24 aluminium cards, box and detailing will be $400, shipping internationally is ok if any interest
All images and video below;
Link to video;
Any questions feel free or PM me, thank you
very interested in some individual cards, if you might be willing to go a la carte!
Hey no problem, thank you will pm for details
For anyone who sees the post in future I am happy to send 1 card, or any number or the full set without box or extras, just happy to get them to people
Interested as well it looks great! The box looks sharp with graphics and plaque on the exterior. Just being cautious already got burnt by Brandomack.
Hello Kreativebox,
I have a question for you. I just finished watching John Wick Chapter 4 and noticed that the card doesn't have a white border around them. The border looks like silver or metal instead. The box also has a white border i know this one is custom will you be offering the cards and box with the high table logo without the white border?? I will have to check out the video you shared later. Work does not allow youtube...L Here a screen grab another member on the ROF had shared. Confirms what i saw on the movie.
Hey, not sure what happened with Brandomack? But I have no ill intentions what you see is what you get. But if it helps a little about me, I am a graphic designer and artist. I got into props and memorabilia when I was gifted Terminator screen used notes when I was younger, then started accumulating and buying pieces. I manage a print and sign workshop which allows me to print on all materials with large format printers, roll to roll machines and so on. But I genuinely just like making cool pieces and sharing them for other people to enjoy, so anything if I do sell is due to me making something for myself and then someone asking me to replicate or thinking someone else may get some joy from it
That is true, I did a few alternatives and in the end settled with a black border. But if it is preferred for the metal to be shown to the end like your screen grabs that was never an issue or oversight.
To be clear on the metal pieces themselves there is no white used. I print directly onto the metal, I do a kind of negative print, which leaves what would be white on my design file to be the metal exposed. I printed some today so got a snap, so my jig will start with the metal pieces laid out in a jig like this;
Then by leaving the areas exposed that I want to have the metal left and to show through, how it looks in the film. So close up you can see like this, leaving the metal exposed to show through from the design (evening at the moment and lighting isn't my friend in my office but hopefully you can see);
With the box there isn't any metal to leave exposed as its made from wood, so I made it white for a better visual. But to be clear my version of the box is completely fictional as you had eluded to, in the original bio I had said I thought how I would like to display them and the best fit, so everything is designed by myself, the top of the box using the branding from the cards, the print on the acrylic, the wooden insert inside and so on. Not based on anything on screen apart from how I imagined it and thought would look best. Just personal choice of what I thought would be in keeping with a high table design and cool way to display and have the side as a display piece
Thank you for explaining your process and sharing photos very cool set up and how you got into it. I am interested like many others here. If its not to much of a hassle. I be interested in the card set without a black outer border. Metal border instead as seen in the screen grabs be over top. Again if its not that big of a hassle. As for the box it just a great piece to tie everything together. I got to see the video and impressive!
I was going to ask about the white lines on the cards myself and the border. enterprise0216 beat me to it. The Brandomack thing is he started a run for a blaster.Took lots of peoples money and never finish the run but kept the money.
Not worries all. With the general consensus being preferred and a good conversation with Astyanax, I did some redesigning last night to the design / print files and I am going to reprint today! So will put images in the thread
As for Brandomack, not my style, this is my passion and profession so I wouldn't want to taint anything, I have also purchased from the site also!
Understand the reservations though but not this guy
Thanks so much for the samples! I think it is MUCH closer to the originals, thanks.
One minor suggestion, but not a huge deal if impractical: I think the black and aluminum borders should be a little thinner. Notice how they are about the same thickness as the gold frame elements?
(This image is blown up by AI for illustration purposes only.)
See the three thicknesses that the red arrows are pointing to? I think if you can hit that we will be right on.
Thanks for inviting scrutiny. We'll try not to be too scary!
Bill
