JFoam Arkham Origin Batcowl build questions
BoosterGoldstar
Hi guys
I am working on this for a friend. Got a couple questions though,
1-For scaling, I am not sure if I should add the thickness of the foam when scaling
2-Do I need to cut a lot of the pieces with a bevel?
Thanks for any help that you can give me.
Bigbat23
If you are going to change the scale, then yes you need to add in the thickness of the foam also. I got lucky and didn't have to change the scale at all. As far as beveled edges, I only did it at the nose and the ears.
