Iron Man MK3 help
cjlocke
Hello, I am new to prop making and have printed out the Helmet of Iron Man MK3. I was wondering where the best section to start is (Faceplate, Top of head etc.) I tried doing the MK6 Helmet and did really bad, there are a lot of small pieces that I couldn't match up correctly especially around the ear. All the help will be appreciated. THANK YOU IN ADVANCE EVERYONE!
Also, Would it be better to scale the whole suit as a whole or piece by piece. I am a small guy about 5'4 - 5'5.
Welcome to the RPF! You might want to familiarize yourself a bit with the forums. You'll get much more feedback by posting in the costuming subforum than you will here in the modeling subforum. Check out the pepakura sticky which should answer most questions you'll come up with :thumbsup
^^^^^ You really want to do that pronto ^^^^^
As for your problem. Have you tried adding the edge id's. You can do this by going into the 2D window and click, "Show Edge ID" it'll tells you were everything goes by matching each number to itself. I would really take Kevin's advice.
