motman241
I'm just starting this thread, so nobody else has to.
Make a run of these? Why?? They're so freaking cheap, and would require so little knowledge, why would someone not try to make their own? That's why this thread is here.
For my display, I'm not going to have any of the light-sensing circuitry. I don't want it to turn on and off by itself. I will turn it on and off when I'M ready.
The hardest part of this project will be deciding if you want to make Ignignokt or Err. :thumbsup
step 1 - decide character, and print design.
step 2 - buy plexiglass. Found at any hardware store. You can probably use thin wood, metal (have to watch grounding/short issues, though), other plastics, real circuit boards, etc.
step 3 - buy the LEDs. Probably the next hardest step. Depending on what character you picked, you should pick appropriate LEDs. Radio Shack will have some, but it will cost a small fortune for as many as you need. It is cheaper to buy the LEDs online. Besides, mall Radio Shacks don't carry parts any more. :unsure
step 4 - transfer design to plexiglass. Cut the LED holes out, and paint the plexi black.
step 5 - wiring. This is an easy one. the + side of the batteries (or other power supply) go to all of the long LED leads. All of the short LED leads get soldered together. Now, depending on what specific LEDs you got, and you power source, you need a resistor. This thread might be the best place for help on this, as there are too many variations to list something definitive. The resistor will go from one of the short leads to the - on the power source/batteries. Oops, I forgot the switch in there. Put that on one side or the other of the power supply. It really doesn't matter which.
step 6 - finishing Probably want to tack loose things into place with some hot glue or electical tape. This could be when you super glue a hanger on the back, too.
done
Please post progress pictures, new ideas or designs, questions, cries for help, etc.
done
