Hula Motion Lamp - 'Blue Hawaii' - 'Lilo & Stitch'
Tikidroid
I'm fascinated by hula motion lamps, similar to the lamps seen in 'Blue Hawaii' with Elvis Presley, and 'Lilo & Stitch', the animated Disney movie. The originals from the 1930s and 40s were in spelter, also known as white metal, usually with a bronze metal surface finish. I'd like to create a replica, preferably in cast bronze, but I can't find many details on the interior mechanics that created the hula motion.
Buying a lamp for research purposes is not an option. Vintage Dodge lamps run several hundred dollars, while affordable modern versions are clearly using a different mechanism producing an inferior looking motion. Charles Moore of Hula Lamps of Hawaii builds beautiful recreations of the vintage models, but his lamps start at over a thousand dollars.
I've identified the motor and found a modern counterpart, but I don't know how the motion was transferred from the motor to the hip rotors that move the skirt. Also, the body separates into two pieces at the hip rotors and I don't know how those pieces joined together.
Is there anyone out there who could provide some details? Closeup photos of the mechanism and of the body joint would be a huge help.
Still doing research on the hula motion mechanism. Found a few photographs of broken lamps, and turned up a patent drawing from 1950 that shows the details of the mechanism, but not the text that explains it. There are other patents that cite this one as an example of "prior art" and I'm still following those threads for now. I appear to be the only one interested in this, but if there is someone out there who could provide photos of a disassembled hula motion lamp and its inner workings, I would greatly appreciate it. hula motion lamp_patent drawing.jpg
Always wanted one of the Joe vs the Volcano variants...good luck! :)
Rob
Sent from [location encrypted]...somewhere on the Tharkside of Barsoom ;)
