wesalexleft
I'm working on my first IM IV costume and learning as I go. Picked up many tips from here to me get started, and now learning my own "technique" as I go as well. Things have been improving and progressing pretty well, until I wanted to build the neckseal and helmet out of thinner foamies. I've been using the 6-7mil fatigue mat from Harbor Freight for most of the build. This foam is thick enough to hold an angle while glueing. When I tried the neckseal with 3mm, it just didn't want to hold the shape. I struggled to get any kind of glue edge as well when butting the pieces together. Then I thought I would try backing it with some 2mm, but that didn't seem to hold a crisp line either. Can someone tell me where I'm going wrong? Should I stick with the thicker foam pad for the neck and helmet? I'd like to get the neckseal completed as my warmup for the helmet. I'd read threads here where people advised to go with the thinner foam for the helmet and neckseal.
Aside from that, upper torso is done. I'm fairly pleased. There are some flaws, but this is going together for Halloween and I'm trying to complete the full suit by then. As usual, I started to late to do the best job, but after the holiday, I may come back and revisit it piece by piece for more of a quality build.
Thanks,
Thanks,
