How to determine how much silicone needed for mold and how much resin needed to cast
Discussion in 'Replica Costumes' started by Moviepropmaker6, Jul 11, 2015.
  1. Moviepropmaker6
    Moviepropmaker6 Active Member
    242
    Hey guys,just wanted to know how you are usually supposed to find out how much silicone you need for a mold and how much resin you need for a cast
  2. the_batdemon
    the_batdemon Sr Member
    1,476
  3. Moviepropmaker6
    242
    Re: How to determine how much silicone needed for mold and how much resin needed to c
    Thanks
  4. Hazmat
    Hazmat Well-Known Member
    566
    Not sure if this will help but an easy way to find an objects volume is to place the object in a container filled with water. The amount of water it displaces will be equal in volume to the object. So if youhad a mold made for an action figure (lets say) and wanted to know how much resin to duplicate it, you could fill a pot with water to the brim. Put that in a larger pot or basin, put the action figure in the pot full of water and the amonut of water that pours over the edge into the larger container has an equal volume to the action figure. Pour that into a measuring cup and you can see how much resin you need.
  5. Moviepropmaker6
    242
    thanks so much , really helped
  6. ichibans13
    ichibans13 Active Member
    242
    L x W x H x 18.5 = total grams / 2 = how much part A or B if you're using something that is a 1:1 ratio. I got that off of one of the videos from Tested's channel on YouTube. They were making a mold of a lightsaber and through that equation up on the screen.
    I don't have any cool equations for resin. The displacement suggestion would work.
  7. fallimar
    fallimar Sr Member RPF PREMIUM MEMBER
    1,036
    Yeah, to find out how much resin I need for a mould I fill it with water and then pour into a cup on a scale. That or into a measuring cup if I want volume rather than weight.
    You can also do a quick volume calculation if you're doing a block mould and subtract the volume of the object, Length X width X height, 1cubic centimetre = 1ml, so a mould that needed to be 6cm by 10cm by 10cm would be 600ml minus the volume of the object(s) to be moulded :)
  8. clarence
    clarence Well-Known Member
    746
    The water is the best way to do it I think Also to derermine how much resin rice or sugar fill mould empty in mixing cup mark level thats the amount needed
Share This Page
