OK, I am trying to figure out a way to do some interesting lighting features in my man-cave do-over. I was playing with an idea where I make a U shaped chanel from pink insulation foam and mount a florescent tube inside and have the light shine out the bottom. (Please excuse the crudeness of the drawing, I only have paint here at work.) The light is a standard off-the-shelf-in-the-USA model that plugs right into the wall.
My question is, with the pink foam enclosing the light tube on the front, back and sides, and on the bottom with light diffusing plastic sheeting, would some simple venting in the back of the U channel be good enough to prevent the florescent tube from catching fire or melting the foam or something?
Not pictured: Pink foam end caps, light diffusing plastic sheeting for the open 'bottom' of the channel, electrical connectors for the light tube.
