Hi sapper,
Cutting a channel is one way that you could make room for wiring. The nacelle pylons were made into two pieces a top and a bottom, to make that task easier.
Instead of grinding out the outside surface of the pylon then filling in with putty and sanding, cut your channels on the inside or mating surface of both parts 13 and 14. Run your wires down the length of each pylon and finish off buy drilling holes into the bottom of part 13 to run your wires thru into the secondary hull. Glue the two pylon halves together, seam up the fore and aft edges and you've got it!
Hi sapper,
Neat suggestion, but I got the ship all together - My last post was about whether I wired things correctly or if I'm underpowering the circuit. I used these LED sets:
http://www.culttvman.biz/cgi-bin/Co...emplates\cult\SearchResult.html&category=XLIT
