Hobbit Sword LOTR Build
Discussion in 'Replica Props' started by Popeanator, May 21, 2012.
  1. Popeanator
    Popeanator Active Member
    341
    This sword build is no specific hobbit's sword.
    This idea came form BFX on there video here
    Pirates of the Caribbean : Sword Tutorial: DIY - YouTube
    The main difference is that I used Mild Steel and not aluminium.
    Mild steel is much cheaper and you can buy it by the meter, also It adds
    some weight to the sword.
    I used a 3mm thick piece by 40mm. The total length is 600mm, I cut it down a bit. It only cost me $1.65 for the entire piece of metal.
    [​IMG]
    [​IMG]
    Is is the sword so far,
    [​IMG]
    [​IMG]
    This is the sword compared with a 40cm ruler.
    [​IMG]
    As I have all the materials already from other builds it will be very cheap to make.
    More to come soon. :)
  2. Popeanator
    341
    Update
    I cut out the craft foam the shape of the blade. To make it more safe I made the tip soft by adding a middle section of foam.
    [​IMG]
    [​IMG]
    The handle is EVA foam **** in half length ways to make is thinner then warped that around the metal handle and used gaffer tape over the top. Going to paint it to look like leather.
    [​IMG]
    [​IMG]
    This is the two halves of the foam glued onto the metal and the edge has been Dremeled to give is a sharp look.
    [​IMG]
    [​IMG]
    Eva foam for the Hand guard in two pieces just shaped it a bit with the Dremel then hot glued it onto the handle. I made it over lap the blade to make them look more like one piece. added a small strip of craft foam bellow the hand grip.
    [​IMG]
    [​IMG]
    [​IMG]
    Painted the handle with black acrylic paint. Made a pummel section with 3 pieces of EVA deep and used the Dremel to shape it.
    [​IMG]
    [​IMG]
    [​IMG]
    That is the sword so far. Going to seal it with some PVA glue and then paint.
    I'm very happy with it so far. Looks great and has a nice weight to it. Will be awesome when painted. I think it's great for my first sword build. :)
  3. thd9791
    thd9791 Master Member RPF PREMIUM MEMBER
    3,001
    hey, cool build! This is my FAVORITE sword prop from the entire series...very sad that there isn't a metal official replica anywhere
  4. AZJedi
    AZJedi Member
    180
    Very nice thus far...
  5. Popeanator
    341
    Hobbit Sword Completed
    Here is the hobbit sword done! Iost the other progress pictures but here you go. Sorry it took so long to post this.:facepalm
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Looks nice an old. This is a great sword. If I make a second one it will be 10x better.:)
Share This Page
