Crimsonnaire
Assuming that the LFL prop department has access to CNC machines, is it likely that they would achieve measurements that go into the hundredth millimeter when making their sabers, or would they likely round the number to the nearest tenth place and settle for a resulting measurement that ends with an odd, non-half (5) integer? I've noticed that every casted plastic piece ends with a tenth decimal of .05 mms.
Also, does casting maintain a hundredth decial place value in millimeters? I understand that all plastic parts were produced by casting, so if the prop team decides that a certain part needs to have the same height as another surface on the saber, and later notes that an exact height would go into the hundredth millimeter decimal, would they aim to have the casted piece under the 3-decimal measurement through compensation by having the prototype piece being made in the exact measurement greater than what casting would take away? How exactly do they go about making the molds? Do they machine a metal prototype to create the mold, in which later it yields a plastic reproduction, or do they go about making the master mold differently?
The reason I am asking is because I have stumbled onto a measurement that reaches the hundredth millimeter, and I'm not sure if I should round it to the nearest tenth place. Of course, another difference is that my measurements will be followed through a non-CNC lathe and not casting.
I appreciate any information or suggestion given.
