Hi i have a 1:1 scale electrobinoculars and want to weather it withe chipped look, what is best used to put on the base color coat (which is black) befor putting on the primary coat white?
so after you paint the white on top of the latex and the paint driesWindsor Newton latex masking fluid, its what id go for, it all depends on the application too, a good way to apply is with a toothbrush, dabbing and kinda scratching it onto the surface?
You get some very cool effects looking very real world worn with this, rather than "blobs" showing black through!
lee
here is what I am weatheringFor me the best way to simulate damage IS damage! I'm serious! If masking doesn't work to your liking, simply mechanically chip the paint with a wide variety of tools/objects you can find anywhere around you.
Masking can appear too soft and uniform on a Real Scale (tm) object, but is fine for scale effects on smaller representations.
Distress that puppy! For real! Use real dirt too. Then seal it all with dull coat.
