Help with latex mask support
Loosewire
Member
Hi everyone,
This is the second mask I have made, the only problem is I don't know how to fill it out so that it isn't all floppy when it is worn. Do you think I should try to attach foam sheet to the inside?
What do you recommend I do?
Thanks.
what kind of latex did you use ? I think your mask is to thin . If you still have your mold , put it in back the mold , and add a additional layer inside the mask. I would suggest to add cheese cloth between layers inside the mask .
When I make latex masks I always incorporate layers of Power Stretch fabric into it. I brush or slush in the first couple of layers then start adding the fabric. Power Stretch takes the latex really well, is stretchy itself and provides a lot of body to the mask. It's available through Burman Industries (BURMAN INDUSTRIES) .
