R2D2 is 18 inches in diameter.Found one extra picture
and two links
View attachment 1641837 ace.277751/https://www.therpf.com/forums/threads/krestys-dagobah-fusion-generator-reactor-furnace-whatever-you-want-to-call-it.284300/Loading…
www.therpf.com
How did you scale the fusion furnace? I'm working on 2 right now. Did the flywheel ever get identified?Can’t say I have any better reference but I’ve been building mine over the last couple of years
If you need any specific photos please let me know and I’ll take them for you View attachment 1641935
I used the reference picture as scale.How did you scale the fusion furnace? I'm working on 2 right now. Did the flywheel ever get identified?
Um, the diameter of the grilled portion, even including the grill slats/protrusions can fit two of them with room to spare, so less than 9 inches.I think it is bigger. About 12 inch
View attachment 1641967 View attachment 1641968
And yes, I am making it in 3D so it is print ready
I know a lot of the r2 builders tend to make them taller to fit a battery charger in then to charge their r2’sAlso, I notice that some people tend to model fairly tall versions of the prop - fairly narrow and slender. From what I can see in the film itself it was kinda short and squat. I've also built a 3D model for printing purposes, and mine looks like this:
Yes you are right there are 11, but modeling and printing a uneven number is difficult. So I made it 12.Doesn't the original prop have 11 fins on the top? I don't think it'd have 10, because that'd be an even number and things like this tend to have odd numbers to reduce unwanted resonance vibrations, or something like that.
