When your paint pools up on lower areas and doesn't stick/builds up to the aimed at areas,.i think either your paint mixture is to thin to build up layers in several pases or your airpressure is to high.
I your case probably both.
When paint is to thin the air will blow the paint to the sides and the solvent in the mixture will dissolve the paint that managed to stick to the surface.
Putting several layers with sufficient drying time in between is the way to go.
When your airpressure is to high the air will just blow the paint to the side and it will pool up on the sides of your spray direction leaving the pointed at spot without paint(spiderleg effect).
I suggest especially with thin paint airbrushed close to the painted surface ,that you lower your air pressure enough so you can paint a point or thin line even on a rounded surface without spiderleg effect and clogging the needle to fast.
Clogging the needle will happen due to too much air which will make the dryer in the paint dry faster or due to too little air wich will give the paint a chance to dry/build up on the needle.
When misting paint when spraying from quite some distance to the aimed at surface your pressure can be high especially with thick paint mixtures,but with thin mixtures aswel,..more air equals thinner layer/more atomisation of the paintmixture
Thicker paintmixture need sufficient airpressure to leave the airbrush so in most cases the airpressure will be higher than with thin mixtures.
With thin paint mixtures you can also mist from up closer to the painted surface but this requires again less airpressure and probably several coats.
For detail work(airbrush close to the painted surface) like on small scaled objects,thin paint is better build up in layers(if more coverage is wanted)but i personally prefer normal(milk consistence or a little bit thinner) mixtures with just enough airpressure to be able to spray a good coverage in one go without spiderlegs or too frequent clogging of the needle(almost unevidable)
Almost touching the painted surface with my needle(aircap removed)
When your needle gets clogged(in this case due to low airpressure) you can easily clean the needle during work with a tissue and some solvent that is if your aircap is removed.
When your aircap is attached you can use a cottonswap with some solvent,.but like i said i prefer the cap removed.
I hope this helps and solved your problem.
Happy airbrushing!
