Help Identifying R2-D2 Part
womo68
Hey Guys,
I'm starting to fill in my R2 dome with servos and gadgets and thought I would add a Periscope and Lifeform scanner. I've got the periscope...and I wanted to stay close to the OT with the scanner. I need help id'ing what type of metal it's made of...here's a couple of pics...
I'm thinking cheese grater or hot-roller hair brush.
What do you guys think? These were the best images I could find of the ESB one.
Thanks for any help, :thumbsup
Wayne
Hard to say exactly....if it is a found item or a cobbled together piece. The mesh looks very similar to the Vader Reveal neck mesh, maybe a smaller pattern. I know that Hobbytown has some similar stuff in the metals section, thin brass/bronze. Good luck.
[snapback]1178497[/snapback]​
thanks for the reply...if anybody else has better screen caps...that would be great if you could share them.
womo
Internal mesh of an automotive oil filter? Or possibly internal mesh from a tubular lawn mower muffler?
Almost looks like carbon fiber. You could go to the auto store and get carbon fiber decals cheap and put them on styrene or metal if you want a cheaper solution. Otherwise i am lost. Dont think its cobbled, the pattern is very perfect and even on the sheet metal. It definately came made from something
dan
Is it just me, or does the base of the scanner (where the arm poking out of the dome meets it) look an awful lot like an adaptor for a car cigarette lighter? The coiled cord would even be already attached.
Please feel free to correct me if someone else has already mentioned this years ago, it's the first time I've ever seen a large pic of it.
I was going to note, in the unidentified SW parts thread here, a pic of the pre-pro Fett gauntlet that shows an extendible metal rod with a coiled wrire around it.
It wasn't used on Fett but I wonder if it made its way onto Artoo as the supporting arm for the "dish"
Originally posted by womo68+Feb 7 2006, 07:37 PM--><div class='quotetop'>QUOTE(womo68 @ Feb 7 2006, 07:37 PM)</div>
<!--QuoteBegin-bobasfett
womo
[snapback]1178501[/snapback]​
[/b]
does anybody have a pic of the vader reveal neck mesh?
thanks guys,
womo
Seeing those pix made me think of my childhood wintertime friend..
Now its definately not this model, but maybe another? The metal piece could be easily be cut out in that shape, and voila..
I agree with bobasfett and kurtyboy it looks strikingly similar to the Reveal mesh (can't find any photo at the moment). I've been looking for it for ages but have all but given up.
I'm pretty sure it's also used as the inside surface of Luke's prosthetic wrist at the end of ESB - check out the shot of 2-1B closing it up after Luke's had his new hand fitted.
Jeremy
Jeremy
[snapback]1178831[/snapback]​
Man, I need to get some pics of that Vader reveal stuff....
Thanks for your help guys. Keep it coming.
womo
Originally posted by ElmoandBloodyShow@Feb 8 2006, 11:29 AM
Looks similar to a hair brush. Remove the bristles and handle, cut it down the center and bam.
similar to these
http://www.folica.com/Ceramic_Tools_R_d973.html
[snapback]1178952[/snapback]​
that's what I thought too...but the holes in the ESB look to be rectangular...All the brushes I've found have circular holes.
womo
Here's what the replica stuff from a Vader Reveal kit looked like:
Originally posted by PropReplicator@Feb 8 2006, 05:11 PM
Vader reveal neck mesh: (This is a borrowed pic from darthblade.com. Let me know if you want it down.)
W.
[snapback]1178973[/snapback]​
Originally posted by kurtyboy+Feb 8 2006, 04:10 PM--><div class='quotetop'>QUOTE(kurtyboy @ Feb 8 2006, 04:10 PM)</div>
<!--QuoteBegin-PropReplicator
W.
[snapback]1179168[/snapback]​
[/b]
that looks pretty dang close. Any contacts where to get it?
Thanks,
Womo
