Thank you so much guys!
Here's a shot of the mold:
It actually started life as Skeletor's:
The flashing wasn't too terrible. It was all very thin. Some more bolts and possibly some straps should help with that, I hope. It was slush cast, poured from the handle. I actually painted some resin in both sides first, let it start setting up, then bolted the halves together and slush cast a few rounds. It really needs some sort of a core support, though. I think I'm going to try a 2 part expanding foam, but I'm worried that it won't make it all the way down the blade before it starts expanding. We'll see. My hope is that I can get a more even coat of resin on the outside, backed by the expanding foam, and get a more even color.
Unfortunately, there are some problems, though. If you like your props all Star Wars-y and wonky, it's right up your alley!
It's not terrible, but it has some symmetry issues. Some of the things I did to try and avoid symmetry problems actually probably caused more issues. The biggest problem is the handle. The friggin' thing came loose when I was pretty much done claying everything up. I thought I got it back in there straight, but I should've removed everything from the clay to be sure. It's mostly noticeable when looking down the thinner, cutting edge side. Holding it makes that go away though.
Even though it's not perfect, (I've been trying to remember the "Done is better than perfect" philosophy,) it's still pretty damn cool! It has a great presence, especially when holding it. It's bigger than it seems! I was surprised when I took a pic holding it. I guess I'd gotten so used to it, and the handle hadn't been attached, it seemed much smaller than the finished piece is. I'll get a better pic of someone holding it. Not that you can really see me, but I'm 5' 10" to give you an idea. I don't have the sword in front of me, but I think it hit 38.25" long, and is 7.5" at the widest point. It's really wild how much the perspective of a pic can make it seem so much shorter.
I hadn't used the hammered paint before, so I thought I'd give it a try, and I knew it would help pick up the weathering. I'm pretty happy for a first attempt at both.
They were out of my normal primers so I ended up using some black primer on the original before molding. It looked good! Wun-dar anyone???
Again, not perfect, but this has been such a long time coming for me. It was worth all the time and effort, for sure. Holding it was a 30 year old dream come true! And yes, it does fit down the back of your shirt.
