Flagwaver
After a couple of years of trying to actually find the time to do various costuming projects that I have been talking about, I have decided to just drop everything and start my Halo project. By dropping everything, I kind of mean that literally. Four Star Wars costumes, a Bleach costume, a Briareous, a Batou, and an angel are as of this moment in a series of plastic bins sitting in a deep and dark corner of the closet in the back of the house.
Right now, I have a plan. That plan is Master Chief. Not just a Spartan, but the big guy himself. That includes a M6G Magnum, a MA5C Assault Rifle, two M9 HE-DP grenades, a Mk VI Spartan Armor, and a Mk VI Body Suit, in that order.
The material I will be doing most of my building out of will be 1mm, 2mm, and 3mm sintra (also known as PVC foam board). If it is good enough for Mandalorian Armor, then it is good enough for a Spartan! To strengthen and help detail it, I plan to use bondo and smooth on. No resin or fiberglass, just good old bondo, sintra, and lots of CA glue.
The first thing I will be making is a maximum-detail M6G using a 1mm sliced file that I will be designing myself. This Magnum will be super detailed. As in, I plan to actually etch in the serial number and manufacturing stamp. It will have a removable magazine that is held in with a magnet, it will have a spring-locked slide, a spring trigger, and the entire left outside plate will cover a bunch of magnets (to lock it against my thigh armor). Not to mention, the magazine will have a faux round on the top, to make it look realistic.
Next up will be a 1mm sliced MA5C. It will be mostly hollow to hold the electronics necessary for the LED light system. The magazine will be magnetically held in the magazine well and will contain the same type of faux bullet as the pistol. The slide will be spring loaded and will cover the battery pack and on/off switch. Finally, it will have a series of magnets on the side to lock it against my back (just like in the game).
Finally, weapon-wise, I will be making the two M9s. I plan to make the template for them, myself. They will be just as high detailed as the other two weapons. They will include a pair of Chicago screws in the side to hold them to the opposite thigh as shown in THIS IMAGE
With the weapons finished, I will be building the HD version of the Mk. VI Spartan Armor. This armor will be higher detailed and will include screen accurate on-model weathering (such as bullet dings and melt-spots). It will also include the necessary lights on the helmet (both shield lights and the bright quad-spotlights) and body. This version will also have the necessary magnets in the right hip for the pistol, screw holes in the left hip for the grenades, and magnets in the back for the rifle. The underside will be padded with black EVA foam to be more comfortable, more forgiving to the under suit, and insulate the body from the electrical system. Finally, it will have a full voice amplifier and fan system in the helmet (possibly with the voice amp behind the chest plate).
In the end, after my body is more in-line with that of what a Spartan should be (starting the P90, P90X, and Insanity training programs now), I will tackle the under suit. It will be made using pleather, spandex, and other necessary materials to make it look like I just walked out of the game. After having worn a full Darth Vader (leather body suit), I know how to properly ventilate under hard armor while giving the normal appearance between armor sections. Not to mention, how to make the suspension system blend into the under suit.
And that is the end of the dreaded WALL-O-TEXT™!!! I’ve already began making the file for the pistol and will be sharing it in the next post. This thread will be a complete WIP, walking through the entire build process in case someone is crazy enough to want to copy my methods. I mean, that’s what WIP threads are for, right?
Wish me luck!
Then again, Spartans make their own luck.
