Done / Completed Graflex Conversion Blade Plugs ** FINAL UPDATE 5/13
Re: Graflex Conversion Blade Plugs
In for an aluminum one, possibly weathered depending on the look of it.
Please refer to Post 1 for the current list! If you need any changes to your interest, please let me know and I will update it! Thanks guys
Definitely in for one. For GRAFLEX 2.0:
7/8's Inch OD
2.25 Inches Length
Brass/Copper Weathered
Black Tubing
I'm in for 2 White brass/copper 1 polished 1 weathered and 1 black brass/copper weathered for Korbanth Graflex 2.0 please :)
Hi.
My apologies but have a question that I truly don't know the answer to. Prior to ordering these, I am confused about the new run of replica Graflex sabers coming out. Do they not come with internal guts already installed like the original Graflex do? If so, are these made to be easily removed and installed to attach the blade?
Hi.
According to Korbanth's Graflex 2.0 threads, it will be a completely hollow hilt with a blade holder already machined and included in the kit. The blade holder holds 7/8" blades, and it appears that the glass eye is to be used as a retention screw for the blades.
I think Plannetera refers to the Roman Graflex. I can take a few shots of my 2.0 when I get back home. Just to show the inner structure.
Roman's Graflex replica will have internal guts like the original Graflex that you can keep as a static display hilt only.
@JaxAndTheMoon Can you update mine to be confirmed for both a 7/8" (Korbanth) and 1" (Roman) Graflex kits? Also, could you please correct my forum handle name on the list? Many thanks!
(now to figure out which kind of plug I need for Roman's Obi Wan kit)
