I'm posting this because I kind of wanted to share this with someone... anyone
I'm not new to modding, I kind of wanted to share this with people who like myself might be looking for alternatives to blaster core (not that what I've done even compares to blaster core), but I honestly didn't want to wait however long for blaster core to be available, but also, I was hoping more people with programming skills might have their interest sparked as I am not a developer and there is a lot of potential with arduino/wave shield... or what I'm using which is a lightduino board from Azulmedia. So it's all open source... Not sure what the rules are about name dropping with products here... so I'll leave it at that as I definitely don't want to step on any toes.
Anyway I'm still hacking away at this thing and will update with my progress, but all go ahead and start with my progress to date...
So just getting the thing apart required much dremeling... all the little details that hide the screw holes on my lancer were glued in pretty good... so I made molds so I could recreate them...
Little molds...
The worst dremel job on the planet... hopefully I can fix it...
Here is the lightduino board... I have it set with 4 buttons so far, one for fire, one for chainsaw, one clip detect and a selector that goes between triple fire and full auto. I also have a jumper going from one of the volume resistors into one of the analog pins that detects volume, I have an output pin to a amber luxeon rebel star so basically it's set for just the machine gun fire, when it reaches a certain volume the luxeon flashes simulating machine gun fire... the luxeon is connected to the arduino output pin and a tip 120 resistor... There's also six accent led's with a pretty cool looking throb effect, and a speaker stuck in a piece of sink tubing.... which I'll actually fix more permanently as this project moves along.
I made molds of the rear parts of the gun where the lights are supposed to go (before the ugliest dremel job ever above ).
Used rubber bands to attach the molds and filled with Alumilite clear urethane casting resin..
It turned out pretty good, a few small air bubbles in the clear resin, but that's pretty much unavoidable unless I'd rigged up some kind of vacuum chamber and basically vacuum cast the whole thing...
Test run with the LED attached...
I'm using 3mm fiber optic, I basically use metal flashing tape to stick it to the clear plastic parts, I do this to basically not have any bright spots and have even smooth light accross the whole plastic piece.
I'd originally tried to use the stock "button thingie" with some pretty terrible results.... So I made a mold, dremeled the whole thing out and started casting some replacement pieces and came up with a better plan for lighting...
Test fitting, of course wires will be inside when project is finished
Anyway... this is as far as I've gotten! I'll post updates as I make progress...
I need to post my arduino code as well, I'll do that later...
Anyway, what do you guys think?
Little molds...
