Fitting parts together - Obi Saber
thd9791
Hey everyone,
I had a question about graflex clamps and the rest - they are exactly 1.5 inches on the inside. The Grenade casting I have is about a millimeter or two less - not a snug fit at all. Is there something in between them? I can't tighten the clamp much further.
Also, 1 inch inside the emitter emitter and .5 inch pipe? are there rubber washers that size or something?
I haven't picked up a booster/old gear yet and I'm hoping that's a little closer hahaha any ideas?
Starsky
Member
I have a similar problem myself because I'm using a replica grenade and a salvaged MR clamp and they're both quite different in size. I was thinking of cutting up some rubber to fit and wrapping it around the grenade, something like a car mat.
thd9791
Found some 1.5 inch Sink Tubing that I was going to use as part of a spacer behind the clamp. That tubing takes care of a mm or two for the most part, still a little slippery though.
Maybe a dowel for an emitter spacer? Drill out for the grenade neck?
Kevin Gossett
Maybe wrap the bottom of the grenade (that is hidden inside the clamp) in black tape to build up the area enough to close the gap?
Sym-Cha
Hi there,
Just make certain when you start swinging and swooshing around with it that the clamp doesn't loose its grip on that wrapped grenade. Perhaps better to secure it more tightly.
-Chaim
Starsky
Member
I view my build as more of a display piece, although I won't be averse to the odd swoosh now and then (with SFX added of course) but with a dignified air about me, similar to how Obi-Wan wielded his saber in ANH.
