First Build Iron Man pep
Bhasbach
Hey Guys this is my first build ever and attempt at making anything that involves paper, resin and bondo. Im Pretty much done with finishing up all parts and some of them are already resin and fiberglass. I started the bondo on my chest piece (but it looks horrible) im going to attempt more sanding and see if it works.
I would appreciate any tips and advice! Thanks
davy
hm why you paint it in red when its not ready ? my tipp is make a new chest and work part for part
Bhasbach
Well I was just in a hurry and decided to see how it would look... I was just being dumb. I already stripped the paint from it and will attempt some sanding to see if it works
animefan
you went to thick on the bondo, use smaller coats, its going to take at least 3 and a crap load of sanding.
bamboodia
I'm with davy on this one. These things take a hell of a lot of time. You can save yourself hours of work if you have a good think about how you're going to approach the next bit. I've taken a few shortcuts in my own project and it's only come and bit me in the ass later on.
Stick with it man and maybe try a smaller piece to gain some practice and experience on before you tackle the big bits.
Bhasbach
Chest piece turned out good. Tho I do have one question, how do you connect the parts that are separated. Im talking like the fore arm that has the 3 different pieces or the shoulder that is 2 pieces. Do I resin them separately? and how do I connect each other? Thanks for the help
