pennausamike.....
ok, stuff on the handle i understand, should be able to manage too...
the metal part was all greek to me...
could you possibly repeat that as though i really do have no idea how to do this.
thanks
After you have prepped the pistol,
prime the the "metal" parts with a sandable automotive primer
like Dupli-color1692 gray hot rod primer,
(available at Pep Boys automotive stores in my area).
LIGHTLY sand the primer with 800 grit paper.
Not enough to remove the primer, just enough to make swirls on the finish.
You can skip the sanding, but it gives the paint a little more "bite".
Then paint with Dupli-Color DA 1603 Semi-Gloss Black.
Most guns can be lightly weathered with
a dry brushing of silver or steel Testors enamel model paint.
Dry brushing is a way to make things look like the finish has worn away, exposing the metal underneath.
The Mal pistol was brass, so brass or gold is used on the main body,
with the silver only being used on the grip/triggerguard area.
Google "dry brushing weathering" for a bunch of tutorials.
Then buy a toy at the dollar store and practice dry brushing the high points to simulate wear.
Practice is really the key.
Rub-N-Buff is a colored wax that can be used for weathering,
but it isn't durable and requires a similar-but-different application approach.
Regular dry brushing is a more useful technique that can be used to weather all kinds of things.
Good Luck,
Mike
My Firefly/Serenity weapons collection:
http://fireflydvd.com/phpBB2/viewtopic.php?t=3541
