booksandcorsets
Hi all!
I've been plugging away on this costume for a bit and now it's on my front burner. I'm making Meredith Stannard, of Dragon Age II, for PAX East.
I'll be doing this with a mix of foam, wonderflex, and some pieces in Apoxie sculpt and, of course, the fabric. So here's what I've done already.
Headpiece was sculpted in Apoxie sculpt, sanded down, and attached to a band of Wonderflex.
I've layered up and created some of the armor out of foam. Here's the shoulders (haven't gotten the second layer on yet):
Lots of work to do on that thus far.
In the meantime, I've been working on the sword. Because it's nearly as tall as the character, and I want to transport it, I've decided to make the hilt and the blade separately and use a nut and bolt to attach it ONLY when it's at a convention. Here's an image of the sword:
As you can see, that hilt is gonna be a pain in the butt. So I crafted it out of NSP Chavant on the actual piping I'm going to use for the hilt.
I then threw a few coats of Rebound 25 on it.
I sliced up the back, then created a two-part mothermold, then pulled a cast right onto the piping in Smoothon 300.
Some cleanup on him yet but I'll get to it! And I haven't been slacking on the rest of the sword. The blade was carved out of a block of pink foam:
Here's an image of how large the sword will be at the end:
That's a 36" yardstick. I threw a layer of fiberglass on the blade, then bondo.
With some smoothing of the bondo...
Still a lot left to do on this build, but PAX East is the beginning of April, so lots of things will happen soon!
