FC Rifle parts
renaissance_man
Hi.
I'm looking for dimensions for the side parts from the FC phaser rifle, I'm going to make a pair from styrene as the 2 I had went missing.
I've highlighted in red the parts I'm looking for, I need dimensions for the pieces from both sides of the rifle, any help would be really appreciated.
Thanks
Jamie
That's a stock picture, I have the rifle kit, and it was missing the 2 side panel pieces.
Can someone help me out with pictures of these pieces from both sides of the rifle, I understand they both have a different internal pattern.
Thanks
Hi,
If you have the rifle why not just messure the part on the one you have?
HMS Mike
well to echo hms mike. if you have a picture of the pieces, and you have a rifle its a no brainer. you can take the measurements on the full size rifle using the pictures as reference.
easy
Just to clear this up, I DON'T have the side panel pieces, the picture in my first post is one I found on the net.
I'm just looking for a little help with the finding out the thickness of these side panel parts, and a good picture of each of the side panel pieces, so I can work out the basic pattern and scratch build a pair for myself to finish off my kit.
Thanks
Mine are 93mm across the bottom, 150mm along the top, and basically 29.5mm wide mine seem to taper at the front a bit. I will try and post some pics in a minute.
Thank you Trekfan_1701-D that's exactly what I was looking for.
I really appreciate the help.
Regards
Jamie
