PlasticineNinja
Member
That is awesome!! Love the game.
Stunning, can't wait to see it finished! Now if only Bethesda would comission you to make a master and then sell a run of replicas. One can only dream.
A few quick questions..
Are you using a router for the tapered inside edge of the circles on the stock?
Also, I'm curious to know what method your using to shaped the styrene and adhere it to the MDF?
Thanks!
Yes, a table router was used to shape the cutouts in the stock. The inside circle was trimmed flat on the table freehand using a straight bit, then the edge bevel was added using a 45º bit with a bearing cap to follow the line of the circle.
Styrene is hand-shaped using various rounded dowels as forms. The sintra is shaped on a table router. As for gluing it to the MDF, I lay down a coat of superglue on the MDF which soaks in and seals the wood, then I put another dab of glue on this and place the styrene on top. Rock-solid.
I forgot to ask. Did you do your layout directly on the MDF or do you use a CAD program and transfer it? It looks penciled on but I couldn't see any compass points in the wood.
