Built using a gen 2 Roman replica Graflex top/bottom and Khal's kit. All rivets/screws are cut down and glued(it still separates if you loosen the bolts under the clamp card). Will include the original lower half from Khal in case you want to buy another set of grips and make it installable. I used his "Tamiya smoke" paint technique on the burn marks, and it's the only part of the weathering I'm not completely jazzed about. The faux-welding looks more brassy in person.
