No that part you see on the box is the part that is below the emitter shroud on the casting... However, some have speculated that it is part of the same found part as the Vader ROTJ stunt box (as in, it was originally set into the bottom of it).
Yea, for this one photo shoot someone put the little block part in the empty control box section. It had fallen off, was originally the "bulb release" up top. there used to be a circuit board in there, and the scrim tape did not succeed!
Are the holes really that off? Looking underneath the DV6 box I can see the same type of pattern.
Interesting - I think I'm falling into the category that they're two version of the same plug or box or switch or relay or....
Doesn't matter where you move the holes to - the distance between them is way off. Also look at the seams.
