E11 build question
Senordeadpool
Hello RPF!
I have the Fieldmarshall e11 kit and Im wondering how the hengstler counter attaches to the scope rail. Theres two tiny holes in the rail but the counter doesnt have any spot to connect to. Should I just drill a new hole in the rail that screws into some spot in the counter like the lower metal part of it? Any help would be appreciated. Thank you!
Marv
You can do it without drilling I have a post on the FISD Whitecroft.net which describes how it can be done. But was with a rail I made but might work with what you have?
Edraven99
Sorry for the minor hijack... but with regards to the FM scope rail, does anyone know if there's enough material to mod it into an "angled" rail and still have it be able to attach to the rear sight?
OdiWan72
Not sure what you are referring to?! Chris‘ rail IS designed to be attached to the rear sight...
Edraven99
Hey Markus... yes, but his rail is designed to attach straight across.
From what I’ve read, many of the screen used blasters had their rails bent down at an angle before it was attached:
(Image from Parts of Star Wars website)
OdiWan72
Ah ok... but the „angled“ rails are not attached to the rear sight but secured directly to the receiver, hence my confusion
Field Marshall
yes,,, you can cut them for the other version im making some but it will be a month or so....
