DO I PUT EPOXY PRIMER ON BEFORE BODY FILLER? need ASAP! Cardboard Iron Man suit!
after the resin dries and you're satisfied with its firmness you can go right into the body filler stage. The primer will go on after sanding the body filler so you could see imperfection that need filling. after you've reached your desired smoothness you add primer again before moving on to paint. hope this is the info you were looking for
