Diamond Select Star Trek TOS Communicator Modification Project / Replacing Parts
spacerone
Going to start modifying an old Diamond Select Star Trek TOS Communicator I had lying around. Fortunately this one has the metal lid attached. Anyone interested in sharing ideas or participating is welcome to do so!:)
spacerone
A little further down the rabbit hole.
Look what I found, it's a little baby speaker. How cute is that! :lol
That's better. Now how does that bezel come off. :confused
I got it! Just press on it. It was glued on.;)
It's off! :)
spacerone
Now back to the project!
I don't want to remove the control plate area which is a tiny bit larger than it should be so I will have to improvise a bit. Time for the Sharpie marker to do it's trick.;)
Now that's a work of art! :lol
Time to make some noise. :devil
Wait that hole is suppose to be a different shape.:cry
I think that is better but I will have to check it with the replacement control panel part to be sure.:p
Will be back right after station identification.:lol
spacerone
A little more magic marker to finish my art work.:lol And a little more filing and presto we have a good fit for the mic.:D
The control panel area looks much better now. !:thumbsup
Time for a J-B Weld break! :popcorn
spacerone
These holes are way too small but a good starting point. Keep them centered if you can.:unsure
The one on the right is good size now. It is the same size as the original hole was.
They need a little adjusting though.
Now those two holes will work .:eek
Need to find a way to get the new aluminum hubs to attach to the plastic ones.:facepalm
Stay tuned! I'll be back! :cool
spacerone
And the project continues.:p
Just installed three little halo's.
How heavenly it looks now.:angel
It's J-B Weld time again! :popcorn
spacerone
Had to trim the spinning wheel so it would fit inside the inner ring.
Went around and around with sand paper.:wacko What a pain! :(
Now it fits inside without touching the sides.:)
Now what is the best way to cut circles out of the plastic moires without marking them up. :unsure
spacerone
Cut the two circles out.
Had to paint the back of the smaller circle with white paint and then put a piece of sticker paper on it so the glue won't show through the paint.
I off centered the smaller circle so it would look like the alpha hero and placed it on the wheel.
This is how it looks when placed inside the inner ring with the clear plastic moire centered on top.
Now with the outer ring on top.
Now isn't that a nice little spider.:)
spacerone
Man, I'm enjoying seeing this progress. ::thumb::
Happy to hear it! :)
I had to reduce the height of the inner ring a little with some sandpaper. It was too tall to fit with motor mechanism in the way.
After many test fits with the communicator partially assembled with the motor mechanism, clear moire and outer ring in place I was able to determine the correct height and centering for the ring.:)
J-B Weld hold her steady !:lol
The new alpha ring now fits like a glove.;)
spacerone
Time to glue on the painted moire with the paper on back.
Maybe a little to the left.:p
That looks better. Maybe just a tiny adjustment.:rolleyes
Now that works for me! ;)
spacerone
The silver paint was a little faded at the mid plate area so I added a fresh coat.
I was told that if you remove one of the solder spots on the circuit board that bridges a connection you can recover one of the Mr. Spock phrases ("Your signal is very weak, can you turn up your gain?").
So I removed the connection at this location and at first it did not work when I went through the phrases.:( But then I removed the batteries for a short while and reinstall them and pressed the button again to go through the phrases and there it was, the extra phrase. It worked! :) How cool is That! :cool
