This is the v1.0 bust that was sculpted by Daz71 of DHEffects. It's a little more exaggerated than his v2.0 bust, but in all honesty I really prefer this version.
Now, first things first, while I can paint up busts and am improving on skintones, I really am NOT any good at painting eyes. So I usually install glass eyes. That was the plan here too. In most busts it's easy to dremel out the eyes (as the resin is about 5mm) and insert the eyes from the inside, but I had a problem here - the neck is too thin to fit my hand up inside the head! So, to solve the problem, I decided to cut a circle out of the back of the head (that would later be covered by hair) large enough to fit my hand inside. In most busts this would be easy, and I started cutting, expecting the resin to be about 0.5-1cm thick.....
I ended up blunting two cutting wheels (and still hadn't cut right through), then I had to use a drill, anf then I had to use a jigsaw! This thing was SOLID. In the end I discovered the resin was actually about 3-4cm thick inside the head; what I thought would be a quick 5 minute job took me about an hour! :lol
I got 38mm glass eyes custom made for me by Tohickon taxidermy from a blu-ray screen-cap I sent them (great value at only $35). Here is one of them next to a normal 28mm human eye (not a great one):
And here's where I am in the paintup - still a way to go (all the darker stripes need added, as well as the bright spots), but I wanted to get a good variation in the base skintone first:
