Crispy Props
I found the plans for the Destiny hunters blade on bungi's website and had to drop my current project and make one.
Some of my methods are a tad unoththadox as I am not very computer minded but they work if you're on a budget.
I started by putting the image on my TV and zooming in till it was the correct size and tracing it onto some 18mm ply wood. Then cutting it out with a scroll saw.
It was then sanded into a ruff shape using a bench sander and some good old elbow grease.
Once shapped the holes were drilled out and the finer edges done with a dremil with a drum sanding bit attached. I thinned the grip a little to make it more comfortable to sit in the hand. I also noticed that the cutting edge was not correct so that was also fixed. (Still no idea how I got that wrong to start with).
To remove the wood grain I gave it a hit of Gray cellulose industrial primer, sanded it back and repeat as many times as was needed.
The logo was cut from 0.5mm styrene and then backed onto more 0.5 for a crisp finish.
An area was dremiled out approximately 1mm down and the pieces glued in.
The gap was filled lovingly with car body filler (or bondo to those over seas) and sanded back.
To ensure the primer didn't clog the detail it was masked over and more coats were added for a smooth finish.
