Death Knight Pep help please?
saiofwrath
Hey all, I was wondering if a seasoned Pep file maker might be able to whip this up fast. I have 2 months to make this armor and a friend suggested that having a Pep file for it might make construction easier. If you can help, please send me a PM.
The Armor (not doing the helm):
That is going to be a beast to pep. You might try Vagabond if you have the model and see if he can unfold it for you.
This might be better suited to a foam floor mat scratch build rather than pep.
Pepakura is a very involved process, whereas foam allows you to get rapid, light weight results, that can add that significant bulk without the weight and rigidity of completed pep pieces.
Good luck!
-Nick
as much as i wish you could do that, you wont be making this costume in 2 months.
first of all you need the game files, which are the 3d models of every single armor piece. those can be aquired from your game files, but its a hell of a job.
second, someone needs to unfold that stuff to make it peppable
3rd, and most time consuming, is pepping that stuff.
just for comparison, i took 3 months only pepping the war machine suit, and thats every day pepping, as i am on holiday.
so if you have something else to do than pepping, e.g. work, that wont play
after that you need to resin it and fibreglass/bondo it, and get all the detail work done, add the painting, i'd say a good six months of a lot of work will be about right
sorry to bust your dreams, but 2 months is probably not doable
Well Nick, the final product is going to be made out of foam, I was planning on using the pep as a reference for making the foam version, something here I can look at and touch rather than something on a screen.
