Dark side multi build WIP (1/72 TIE Advanced x1, 1/144 TIE Striker & combat assault tanks)
JNordgren42
I've started building my 1/72 TIE Advanced x1 and the Imperial contingent of my 1/144 Rogue One U-Wing set (TIE Striker and Imperial combat assault tanks). My hobby shop was out of both Tamiya rattle can Fine Surface Primer and Mr. Surfacer 1500, so I'm trying out a new product: Modo* MK-11 Surfacer (lacquer based). Because it's new to me I started out with just one of the tanks to make sure there were no issues. It dries exceedingly fast, and came out very grainy on my first try. I knocked the grainy dusty paint of with a soft stiff bristled brush and tried again with a little more thinner, a little less air pressure, and keeping the airbrush tip closer to the subject. This time I was very happy with the result, so I sprayed the other tank and the cockpit parts of the TIE Advanced and the Vader figure. Now that I have it dialed in, I'm really happy with the product. It builds up very evenly, covers very well, and does a great job of preserving fine details without building up in the cracks and corners.
The signature "taking a constitutional" Bandai figure pose...
The Modo* MK-11 surfacer had no problems with the extremely fine details on the kyber cristal containers for the tanks.
Tanks also showing reat details.
Analyzer
It is very misleading how small those tanks are compared to the size they appear in your pictures
That primer did a great job of bringing out those details
JNordgren42
Yeah, I'm very happy with how it performs. Especially with Mr. Leveling Thinner instead of regular lacquer thinner. I sprayed the TIE Striker last night and it came out great even on the solar collector screen on the wings. I also sprayed a Mr. Color gloss black base coat on Vader and the same for an undercoat on the tanks and it goes over it really well. They also make it in white (MK-13) and black (MK-12), I'll probably pick some of both up next hobby shop trip.
JNordgren42
I made some Progress on Vader's TIE. The cockpit is complete and the body is all put together and buttoned up. Everything has been primed and it's on to painting.
On another note, I framed and hung my JPL space travel prints and some gorgeous lithographs of the space shuttle as well as my shuttle mission pins. The shuttle stuff is from my grandfather, who was an engineer at Rockwell on the shuttle project. They're probably my most cherished possessions and bring back great memories if him whenever I look at them. I'm ecstatic to have them finally up and displayed.
And some pics of my office and the prints.
JNordgren42
The main grey color is sprayed on the Advanced and the body of the Striker and the solar panel color is sprayed on the Striker's wings (I'm doing the panel colors in the opposite order to make it easier to mask). I added a little grey to the black for the panels so I have someplace to go when weathering.
JNordgren42
For anyone following along who has built the x1 and sprayed the paint, what strategy did you use for masking? I thought it would be easier to paint the grey and then mask and do the black, but all of the greeblies close to the edges of the panels are proving to be problematic. I spent 3 hours last night working on masking it out and didn't even finish one wing. And I'm also concerned about not getting it down tight over some of the greeblies (especially around the hexagonal connection area on the inner surface). I'm thinking it might be better to just spray the black and then mask it off and clean up the grey. I'll need to make sure the tape edges are burnished down really well, but I'm hoping it will go better.
starks
Lovely work! Thats a Bandai kit?
Just looking at it I would be doing the black first, then mask for the grey.
Cheers,
Josh
JNordgren42
Cheers,
Josh
Thanks! And yep, it's the Bandai. I decided to switch up my plan and do the black first. While I was at it I decided to go ahead and preshade the body. I'll have to redo the grey, but I think it will be worth it since there is almost no variation in color otherwise. Hopefully it will ad a bit of depth to it.
JNordgren42
I've been in masking hell the last two nights. I managed to get one wing completely masked off and I plan on finishing the other and spraying the grey (again) this weekend. I don't think switching up my paint order has made anything quicker or easier in the end, but the shading should be worth it.
starks
Special tapes are only really required when masking a line on a flat surface.
Something like this where you have a defined edge to mask to bleeds and masking edges are not an issue so dont require fineline or special tape. Just do a bulk quick tape over the entire area, push the tape down firmly and run a blade along the edge and pull the excess tape off. Both those panels should be masked out in under 10 minutes.
Cheers,
Josh
JNordgren42
Cheers,
Josh
I'm a little anal about masking (well, just about everything if I'm being honest). I've found that I quite like the Bandai sticker material. It's got just the right amount of adhesion, is fairly flexible, and gives a fantastic edge. I'm sure it's overkill for something like this, but I was worried about the tape lifting or otherwise not conforming correctly on the tiny ridges at the edges of the panels. :)
JNordgren42
The wings on the TIE Striker are painted and it's mostly assembled now. I just need to do the dark grey and give it a light weather and I'm done.
