dangers of using lasers as light sources?
hydin
Any chance someone on here has a decent working knowledge of lasers? Mostly pointers (green, red, blue).
I have a display idea and I want to not blind myself, or other people, or animals. I know where the laser itself will be pointing and how the setup will be, but I am worried about IR radiation.
Shoot me an email if you can help out, and thanks.
Hit up Google, tons of good reading, there are many factors to consider... Also hit up the FDA warning label laws as they are informative as well...
Color
Power output
They all come into play... I know for a fact that there are a ton of articles that detail the potential for harm in detail... I did a bunch of research before I made the final decision the include a real laser pointer in my Proton Gun light kit, and found out that for the most part the red consumer laser pointers (Class IIIa) are nearly harmless... The chance of permanent harm from them is insignificant unless the perfect circumstances are created... And when I say created I mean just that they most likely will never happen, the exposure time to the eye needed to cause damage (1,000 seconds) is well in excess of the time between your eyes natural blinking... Ad to that the eye and laser would have to remain static and not move one bit with the laser exactly focused on the same location of the eye for this period of time... So short of your eyelids being forced held open for 16+ minutes, your eye movement totally immobilized and the laser held perfectly still and being viewed through magnification, permanent damage from a Class IIIa laser is a no go... But, this is only in regards to Class IIIa lasers...
Class I and Class II are considered harmless to the human eye...
It's not until you get the Class IIIb that you have to really worry about eye damage...
Class IV causes all sorts of damage, including fires...
Most of the negative publicity of "you will blind yourself" is simply over exaggerated urban myth and media hype... That is until you reach the Class IIIb level...
Cool. I will dig around and see what I can find.
I would rather play it safe with this kind of stuff than just assume "OH, pfft, it will turn out alright" like I tend to do most things :)
The only real irritation is the place I was planning to buy the lasers from doesn't have the class written on them, just the mW, so I hope there is a guide somewhere.
Thanks for the info!
So would it be safe to assume that the red laser pointers they sell for $1 are harmless?
YES, for the most part they are... But, like many thing under the perfect circumstances they could cause some harm... But, unless they are being viewed through magnification, or being viewed directly for very long extended periods of time they are for the most part harmless...
It's always best to avoid direct eye contact even though just to be safe...
Like I said the reports and information is out there for the reading, including the debunking of the most of the hyped "you will go blind" hysteria surrounding the low powered pointers... Just hit up Google...
If you want to be absolutely sure, put a lens with a short focal length in front of the laser. That should make sure the beam is spread sufficiently to prevent any danger.
RPF Disclaimer: All claims made by members do not necessarily reflect the opinion of the site operators or other members. Any advice given should be taken at your own risk.
:lol
Just in case someone thought it was a good idea to go ahead and zap themselves in the eye.
Found this today. Seems apt.;)
:lol
Indeed! I wasn't going to go out and experiment on myself to find out for sure.:lol
It's nice to know, but I'll still exercise caution.
