D-Projects: Forbidden Planet BC Build
Discussion in 'Replica Props' started by Delmustator, Feb 4, 2012.
  1. Delmustator
    Delmustator Sr Member
    1,526
    Hi All - Del here with another project on the table. This time around, a buddy has asked for a BlasterCore to be installed in a Forbidden Planet blaster.
    So here we go...
    Not sure who originally built the prop but it's pretty nice. There is plenty of room inside for all the electronics.
    [​IMG]
    Here, I am working on the BlasterCore chassis. I'm like for the entire electronics pack to be removable all at once. In this case, the electronics will be attached to the blaster cone. This is just a rough construct to see how it all fits.
    [​IMG]
    Once everything is fitted. I'll start working on the sound files for the BC.
    More Pics to follow as progress continues... :love
  2. phase pistol
    phase pistol Master Member RPF PREMIUM MEMBER
    2,940
    Ooo, FP blaster, one of my old favorites. :cool
  3. AMP
    AMP Well-Known Member
    746
    Nice! Can't wait to see it finished.
  4. ONEYE
    ONEYE Sr Member
    1,981
    I've got to get one of those!
  5. Delmustator
    1,526
    Didn't like the way the BC chassis was turning out so I trashed that idea and started from scratch. Now it fits snugly in the blaster. I switched to 18650 Sanyo cells as well.
    [​IMG]
  6. Delmustator
    1,526
  7. rad1701
    rad1701 Sr Member
    1,671
    Love it! Looks terrific!
  8. racprops
    racprops Sr Member
    1,681
    That sure look like on of my older versions, with a flosted tip as I could not find a shop to polish them.
    I put a metal tupe in the mold and with some was able to pull it out, later I just left the tube in and cut the ends off.
    This was a light only version as it has no openings in the rear cap for the sound to get out.
    I might be able to spare a cap adn start if you want them.
    Rich
  9. E Q
    E Q Active Member
    341
    Cool video/build! I bet if you did that outside at night, they could see it from space!
  10. Delmustator
    1,526
    Hi Rich, I'm not sure who made this one. Did you embed the trigger switch into the resin? There was no metal tubing inside this one. I plan to router a socket in the endcap for the speaker with some very small sound holes drilled perfectly in the cap to allow the sound out. The customer was more LEDs so I'm looking for some really small ones that will fit the build.
  11. Delmustator
    1,526
    LOL - I was definitely seeing star spots after looking at it flash. :facepalm
  12. exetor999
    exetor999 Member
    180
    No, I had one of those from RAC props, and I noticed that the side flanges were not that thick, I had to thicken mine up, to keep them from breaking off. I later got one at a convention that looks just like yours, but the back end had a screw on it, so it could be screwed in, and unscrewed, which I really loved, to replace the battery and get to the electronics. And it had thick flanges on the side, like the one you show here. I will have to pull them out of storage, so I can show you the difference.
    Thanx for sharing that photo, takes me back.
  13. Delmustator
    1,526
    Had a small criticality accident with the last power source that forced a re-design. New chassis built with non-conductive materials.. Ooooppsss
    [​IMG]
  14. racprops
    racprops Sr Member
    1,681
    Sadly as the mold was used the side fin got thinner.
    IF I had time and over 10 orders I would redo the whole model, using metal for the fins and rear cap.
    Rich
  15. racprops
    racprops Sr Member
    1,681
    There was two ways I did that, the early model had a side cover in the handle that was glued on and then the seams filled, I think I can see the fill on that model.
    The later models I had a lower 1/2 of the handle that is fitted into the upper section and captures the trigger and micro lever switch and then the seam is filled before painting.
    Rich
  16. Delmustator
    1,526
  17. Delmustator
    1,526
    Update
    This is the new Blaster Core chassis. It's non-conductive this time. So no battery meltdowns. I've added blaster charge level LEDs. They are only view-able with the end cap removed. I would make them view-able externally but I hate drilling on a hard to replace prop.
    The recharge/kill port is visible here.
    [​IMG]
    [​IMG]
  18. BAK55
    BAK55 Well-Known Member
    866
    WOW! Just saw your test of the blaster. That flash and sound effect would be enough to chase the Id monster away.
  19. Delmustator
    1,526
    OK, it's done...
    [​IMG]
    Custom sound fonts from the movie are installed.
    [​IMG]
    The owner should love it...
    P.S. Here is a sample of some of the sounds used in the blaster..
    Forbidden Planet Sound Sampler
  20. Caladonis
    Caladonis Member
    191
    This looks great and very bright. This is one of my favorite prop designs.
    Are there any measured plans or drawings for this from the original? The original from profiles in history was beautiful.
    I have a cast version of this that is really really rough (the barrel and christmas tree is out of round, and almost egg shaped) so I would eventually like to get a decent version. Mine looks ok as a display as long as you don't get to close :unsure
  21. Delmustator
    1,526
    I don't have any measurements. I'm sure someone here probably does.
  22. sgtfury4017
    sgtfury4017 Active Member
    342
    That is SUPER COOL!!!! One of my favorite movie blasters. Amazing job!!!
  23. modeleers
    modeleers Sr Member
    1,046
    Del, Great job on the electronics. I'm working up a completely new pattern for the Blaster Pistol. Could you write my Eddress & so I have yours - panotraguis@comcast.net
    I wanted to ask you a few things about your electronics rig.
  24. Delmustator
    1,526
    Email sent..
Share This Page
