Custom Made Darth Vader ROTS WIP
Discussion in 'Star Wars Costumes and Props' started by JUSTINIAN, May 21, 2012.
  1. JUSTINIAN
    JUSTINIAN Sr Member RPF PREMIUM MEMBER
    1,035
    I am working on making an accurate ROTS Darth Vader, completely from scratch. I started out with making a leather body suit from old clothes and some leather material.
    I started out with an old pair of pants that were very light weight (I was expecting it to get hot, so I wanted to cut back wherever I could)
    [​IMG]
    After I took all of the extra stuff off (pockets, belt loops, buttons, etc.) I cut them apart into four sections and labeled them accordingly. Front left, back left, front right, and back right. Then I laid them out on the leather material and cut out the sections.
    [​IMG]
    To get filled out effect I was looking for I put 2 layers of quilt batting (the cotton padding the goes inside blankets) between the old pants and the leather. I had to use 2 layers, because 1 wasn't enough to get it raised high enough.
    I took a yard stick and drew 1 inch lines on the pants, and quilted along them.
    [​IMG]
    [​IMG]
    4 hours later I had all four sections quilted.
    [​IMG]
    Then I sewed the sections together.
    [​IMG]
    I added a zipper and button, to make it easy to take on and off.
    Here I am weraing the completed pants.
    [​IMG]
    They are quite flexible, but pretty heavy duty and very hot.
    [​IMG]
  2. JUSTINIAN
    1,035
    I started out with an old T-shirt and cut long sleeves out of another old shirt.
    [​IMG]
    All of the quilting done.
    [​IMG]
    After sewing the top part of the torso together I made sure I could get my head through, and it fit well.
    [​IMG]
    Here are the sleeves sewn on.
    [​IMG]
    Here it is complete.
    [​IMG]
    [​IMG]
    Here is the full body shot.
    [​IMG]
  3. Eopie Herder
    Eopie Herder Sr Member
    1,296
    So you designed it as a slip on shirt instead of having a zipper? Interesting!
  4. camerafx24
    camerafx24 Active Member RPF PREMIUM MEMBER
    291
    look's great.
  5. JUSTINIAN
    1,035
    I actually needed this for another costume, and didn't have time to put the zipper in. I would eventually like on though.
    I also was able to get a pretty good start on the shins. I made one out of pepakura, just to make sure my size was right.
    [​IMG]
    [​IMG]
    I then did a layer of fiberglass on the inside to strengthen it.
    [​IMG]
    Then I started my Bondo work.
    [​IMG]
    I used a laser to cut out the detail for the shins, and then glued it into place.
    [​IMG]
    [​IMG]
    After a lot of sanding I am pretty pleased with the way they turned out.
    [​IMG]
    [​IMG]
    I still need to finish the detail on the indentations. I'm hoping to get back to work on them soon.
  6. poholio
    poholio Active Member
    211
    This is looking great! You are giving me some ideas for my own build. Thanks for posting this.
  7. JUSTINIAN
    1,035
    I'm glad it was helpful. Yours gave me some ideas for some of the small bits.
  8. Rysjin7717
    Rysjin7717 Well-Known Member
    866
    lTh' dark lord of th' sith evil incarnante that commands with a iron fist I find your lack of faith disturbing!!!! nice shirt and pants good work on th' shins as well i'll be keeping my eye on this thead for sure brah.:cool:cool
  9. JUSTINIAN
    1,035
    Well after a long time, I have finally returned to this project. :D
    I spent a ridiculous amount of time sanding and tweaking and filing on these stupid indents on the shins. But they are almost done.
    [​IMG]
    [​IMG]
    I just have to do some small filler in a few spots and then they will be pretty much done.
    As always let me know what you think, or if anything needs adjustment.
  10. omel
    omel Well-Known Member
    935
    wow those shins turned out amazing...wish i had the same patience and talent when it comes to bondo and sanding...
  11. poholio
    211
    Those shins are looking spectacular!
  12. BenCozine
    BenCozine Active Member RPF PREMIUM MEMBER
    441
    Really interesting work, love the shin guards.
  13. Rysjin7717
    866
    Lovin' those shins brah, you've done some accurate work there.:cool
  14. AZJedi
    AZJedi Member
    180
    Wonderful work thus far!
  15. JUSTINIAN
    1,035
    Thank you all for the comments.
    Ok. After some thought, I have decided to mold these. I did some fine tuning, and made one of the shins to be completely symmetrical, so it can be molded and then create castings for the left and right. I had to bring in the bottom ankle parts, because they flared out too much. I also did some more tweaking on the indents. And then it was ready for the spikes. Here is the final primer:
    [​IMG]
    [​IMG]
    I hope to get the gloss black done on it within the next few days, and then I can start the molding process.
    Hope you enjoyed seeing this as much as I have.
  16. omel
    935
    that is beautiful bro! BEAUTIFUL
  17. James Kenobi 1138
    James Kenobi 1138 Master Member RPF PREMIUM MEMBER
    3,355
    Those shins are ace, great work.
  18. JUSTINIAN
    1,035
    Thanks, guys.
    I finally got the clear done.
    [​IMG]
    [​IMG]
    [​IMG]
    I should be ready to mold it tomorrow.
  19. JUSTINIAN
    1,035
    I got my clay in finally, and built it up for the mold.
    [​IMG]
    Here is the print layer of silicone.
    [​IMG]
    Hopefully later I can add a thicker layer.
    Enjoy.
  20. omel
    935
    Daaang Bro! that is gorgeous! if only you were in my country i'd order a pair of those shins if you ever make a run!
  21. pinder91
    pinder91 Sr Member
    1,880
    Wow! Very inspiring, man. Can't wait to see what's next.
  22. Rysjin7717
    866
    Justinian, that is some phenomenal work on those movie accurrate shins brah!!!!:cool:cool
  23. JUSTINIAN
    1,035
    Thanks guys. I always appreciate your comments.
    After 5 layers of silicone, a layer of rondo, and then a layer of fiberglass, this mold is ready. I ran out of my regular resin, and luckily found another can on a shelf, that is why the fiberglass jacket is two colors.
    [​IMG]
    Here are both parts all trimmed out.
    [​IMG]
    And the final assembly.
    [​IMG]
    I also got some more casting resin in, but that will have to wait until next week.
    Hope you enjoyed this.
  24. Rysjin7717
    866
    All of th' details of th' original have been captured in th' mold great job brah.:cool:cool
  25. JUSTINIAN
    1,035
    Thanks.
    I did my first set of pulls. I sprayed primer into the mold, and then put down 2 layers of fiberglass mat. There are a few imperfections, but overall I am very pleased.
    [​IMG]
  26. Turrican
    Turrican Active Member
    342
    If you should offer a set of those, count me in for one.
    They look realy close.
  27. Toxx
    Toxx Well-Known Member
    567
    Why don't you go with a black gel coat?
  28. Turrican
    342
    Maybe cause it's very toxic?
  29. JUSTINIAN
    1,035
    Thank you. I will eventually get to casting up some. I just want to get this build completely done, before I try to do anything else with it.
    I didn't have any gel coat, and I knew that fiberglass works well enough. I have also heard that gel coat is pretty tricky to get right. In the future I may experiment with it, but for now this works fine.
  30. DynamicMenace
    DynamicMenace Active Member
    460
    wow man those tuned out amazing. very nice craftsmanship. looking forward to the rest of the build
Share This Page
